주요 콘텐츠로 건너뛰기
Lenovo IdeaPad 310-15IKB Battery Replacement
필요한 것
  1. Lenovo IdeaPad 310-15IKB Battery Replacement, Unfasten the lower case: 1 단계, 이미지 1/2 Lenovo IdeaPad 310-15IKB Battery Replacement, Unfasten the lower case: 1 단계, 이미지 2/2
    • Flip the laptop over with the hinge facing away from you.
    • Use a Phillips screwdriver to remove the twelve 6.5 mm screws that secure the lower case and the right panel.
    • It's not necessary to remove the lower left panel unless you intend to replace the HDD.
  2. Lenovo IdeaPad 310-15IKB Battery Replacement, Remove the right panel: 2 단계, 이미지 1/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Remove the right panel: 2 단계, 이미지 2/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Remove the right panel: 2 단계, 이미지 3/3
    • Insert the flat end of a spudger into the notch on the upper left corner of the right panel.
    • Pry the panel up to release the retaining clips that secure the panel.
    • Remove the panel.
  3. Lenovo IdeaPad 310-15IKB Battery Replacement, Unfasten the motherboard: 3 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the three 6.6 mm screws that secure the motherboard to the lower case.
  4. Lenovo IdeaPad 310-15IKB Battery Replacement, Disconnect the fan cable: 4 단계, 이미지 1/2 Lenovo IdeaPad 310-15IKB Battery Replacement, Disconnect the fan cable: 4 단계, 이미지 2/2
    • Use tweezers or your fingernails to lift the fan cable connector directly up and out of its motherboard socket.
  5. Lenovo IdeaPad 310-15IKB Battery Replacement, Release the ZIF connectors: 5 단계, 이미지 1/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Release the ZIF connectors: 5 단계, 이미지 2/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Release the ZIF connectors: 5 단계, 이미지 3/3
    • Use the flat end of a spudger or a fingernail to flip up the ZIF locking flaps on the keyboard and trackpad connectors.
  6. Lenovo IdeaPad 310-15IKB Battery Replacement, Disconnect the keyboard ribbon cable: 6 단계, 이미지 1/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Disconnect the keyboard ribbon cable: 6 단계, 이미지 2/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Disconnect the keyboard ribbon cable: 6 단계, 이미지 3/3
    • Use blunt tweezers to pull the keyboard ribbon cable directly out of its socket.
  7. Lenovo IdeaPad 310-15IKB Battery Replacement, Disconnect the trackpad ribbon cable: 7 단계, 이미지 1/2 Lenovo IdeaPad 310-15IKB Battery Replacement, Disconnect the trackpad ribbon cable: 7 단계, 이미지 2/2
    • Use blunt tweezers to pull the trackpad ribbon cable directly out of its port.
    • Grip and pull the blue pull tab, not the entire ribbon cable.
  8. Lenovo IdeaPad 310-15IKB Battery Replacement, Disconnect the wireless card cables: 8 단계, 이미지 1/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Disconnect the wireless card cables: 8 단계, 이미지 2/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Disconnect the wireless card cables: 8 단계, 이미지 3/3
    • Use the pointed tip of a spudger to gently pry up and disconnect the two antenna cables from the wireless card.
  9. Lenovo IdeaPad 310-15IKB Battery Replacement, Open the laptop lid: 9 단계, 이미지 1/2 Lenovo IdeaPad 310-15IKB Battery Replacement, Open the laptop lid: 9 단계, 이미지 2/2
    • Flip the laptop over and open the lid.
  10. Lenovo IdeaPad 310-15IKB Battery Replacement, Unclip the left edge: 10 단계, 이미지 1/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Unclip the left edge: 10 단계, 이미지 2/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Unclip the left edge: 10 단계, 이미지 3/3
    • The keyboard assembly is secured to the lower case by plastic retaining clips. You'll hear and feel them release as you work.
    • Insert the tip of an opening pick into the seam between the top left corner of the lower case and keyboard assembly.
    • Slide the opening pick down to the bottom left corner to release the clips.
  11. Lenovo IdeaPad 310-15IKB Battery Replacement, Unclip the front edge: 11 단계, 이미지 1/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Unclip the front edge: 11 단계, 이미지 2/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Unclip the front edge: 11 단계, 이미지 3/3
    • Insert the tip of an opening pick into the seam between the lower left side of the palm rest and the lower case.
    • Slide the opening pick to the right to release the clips that secure the front edge.
  12. Lenovo IdeaPad 310-15IKB Battery Replacement, Unclip the right edge: 12 단계, 이미지 1/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Unclip the right edge: 12 단계, 이미지 2/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Unclip the right edge: 12 단계, 이미지 3/3
    • Insert the tip of an opening pick into the bottom right seam between the chassis and keyboard assembly.
    • Slide the pick toward the top right corner to release the remaining retaining clips.
  13. Lenovo IdeaPad 310-15IKB Battery Replacement, Remove the keyboard assembly: 13 단계, 이미지 1/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Remove the keyboard assembly: 13 단계, 이미지 2/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Remove the keyboard assembly: 13 단계, 이미지 3/3
    • Lift the keyboard assembly off of the chassis.
  14. Lenovo IdeaPad 310-15IKB Battery Replacement, Disconnect the battery: 14 단계, 이미지 1/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Disconnect the battery: 14 단계, 이미지 2/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Disconnect the battery: 14 단계, 이미지 3/3
    • Use two opening tools or your fingernails to gently "walk" the battery connection directly out of its motherboard socket.
  15. Lenovo IdeaPad 310-15IKB Battery Replacement, Unfasten the motherboard: 15 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the four 3.3 mm screws that secure the motherboard to the lower case.
  16. Lenovo IdeaPad 310-15IKB Battery Replacement, Release the display cable ZIF connector: 16 단계, 이미지 1/2 Lenovo IdeaPad 310-15IKB Battery Replacement, Release the display cable ZIF connector: 16 단계, 이미지 2/2
    • Use the flat end of a spudger to flip up the ZIF locking flap that secures the display cable.
  17. Lenovo IdeaPad 310-15IKB Battery Replacement, Disconnect the display cable: 17 단계, 이미지 1/2 Lenovo IdeaPad 310-15IKB Battery Replacement, Disconnect the display cable: 17 단계, 이미지 2/2
    • Use blunt tweezers to pull the display cable directly out of its motherboard socket.
  18. Lenovo IdeaPad 310-15IKB Battery Replacement, Unseat the display cable: 18 단계, 이미지 1/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Unseat the display cable: 18 단계, 이미지 2/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Unseat the display cable: 18 단계, 이미지 3/3
    • Use tweezers to lift the display cable vertically to unseat it from the motherboard.
    • The display cable is attached to the motherboard with a mild adhesive. Lift gently to avoid damaging the cable.
  19. Lenovo IdeaPad 310-15IKB Battery Replacement, Disconnect the speaker cable: 19 단계, 이미지 1/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Disconnect the speaker cable: 19 단계, 이미지 2/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Disconnect the speaker cable: 19 단계, 이미지 3/3
    • Use the pointed end of a spudger or your fingernails to gently "walk" the speaker cable directly out of its motherboard socket.
  20. Lenovo IdeaPad 310-15IKB Battery Replacement, Release the HDD and I/O board ribbon cables: 20 단계, 이미지 1/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Release the HDD and I/O board ribbon cables: 20 단계, 이미지 2/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Release the HDD and I/O board ribbon cables: 20 단계, 이미지 3/3
    • Use the flat end of a spudger to flip up each of the two ZIF locking flaps that secure the HDD and I/O board ribbon cables to the motherboard.
  21. Lenovo IdeaPad 310-15IKB Battery Replacement, Disconnect the HDD and I/O board ribbon cables: 21 단계, 이미지 1/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Disconnect the HDD and I/O board ribbon cables: 21 단계, 이미지 2/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Disconnect the HDD and I/O board ribbon cables: 21 단계, 이미지 3/3
    • Use blunt tweezers to disconnect the the HDD and I/O board ribbon cables from their motherboard ports.
    • Grip and pull the blue pull tabs, not the entire ribbon cable.
  22. Lenovo IdeaPad 310-15IKB Battery Replacement, Disconnect the optical drive ribbon cable: 22 단계, 이미지 1/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Disconnect the optical drive ribbon cable: 22 단계, 이미지 2/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Disconnect the optical drive ribbon cable: 22 단계, 이미지 3/3
    • Use the flat end of a spudger to flip up the ZIF locking flap that secures the optical drive ribbon cable.
    • Use blunt tweezers to gently pull the optical drive ribbon cable directly out of its motherboard port.
  23. Lenovo IdeaPad 310-15IKB Battery Replacement, Remove the motherboard: 23 단계, 이미지 1/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Remove the motherboard: 23 단계, 이미지 2/3 Lenovo IdeaPad 310-15IKB Battery Replacement, Remove the motherboard: 23 단계, 이미지 3/3
    • Slightly lift the right side of the motherboard.
    • Slide the motherboard a few millimeters to the right to unseat the ports from the lower case.
    • Grasp both sides of the motherboard and lift it up and out.
  24. Lenovo IdeaPad 310-15IKB Battery Replacement, Battery: 24 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the two 3.3 mm screws that secure the battery.
  25. Lenovo IdeaPad 310-15IKB Battery Replacement: 25 단계, 이미지 1/3 Lenovo IdeaPad 310-15IKB Battery Replacement: 25 단계, 이미지 2/3 Lenovo IdeaPad 310-15IKB Battery Replacement: 25 단계, 이미지 3/3
    • Lift the top edge of the battery slightly.
    • Grasp the battery with both hands and remove it.
결론
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our answers community for help.
다른 2명이 해당 안내서를 완성하였습니다.
Connor Bassolino
회원 가입일: 03/29/22
6,543 평판
안내서 28개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,163개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 34
30일 전: 160
전체 시간: 1,534
