주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Flex 5-1570 Battery Replacement
필요한 것
  1. Lenovo IdeaPad Flex 5-1570 Battery Replacement, Back Panel: 1 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Battery Replacement, Back Panel: 1 단계, 이미지 2/2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Battery Replacement: 2 단계, 이미지 1/3 Lenovo IdeaPad Flex 5-1570 Battery Replacement: 2 단계, 이미지 2/3 Lenovo IdeaPad Flex 5-1570 Battery Replacement: 2 단계, 이미지 3/3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Battery Replacement: 3 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Battery Replacement: 3 단계, 이미지 2/2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Battery Replacement, Battery: 4 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Battery Replacement, Battery: 4 단계, 이미지 2/2
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5-1570 Battery Replacement: 5 단계, 이미지 1/3 Lenovo IdeaPad Flex 5-1570 Battery Replacement: 5 단계, 이미지 2/3 Lenovo IdeaPad Flex 5-1570 Battery Replacement: 5 단계, 이미지 3/3
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 4명이 해당 안내서를 완성하였습니다.
Nate Blake
회원 가입일: 01/23/20
507 평판
안내서 4개 작성하였습니다
Cal Poly, Team S2-G6, White Winter 2020 Cal Poly, Team S2-G6, White Winter 2020 회원
CPSU-WHITE-W20S2G6
4 회원들
안내서 13개 작성하였습니다
댓글 3개
Hullo. In the pic on step -1, near the top left screw, the back cover is cracking up. Whenever, I open the Display panel, the back panel at this point shows tendency to open. The screw is obviously is out of its threading. Is this damage, physical or due to battery swelling. My battery life seems alright. After full charge, it stays for more than 30h with intermittent use. Can you reply to svnarasimhan5@gmail.com
Narasimhan SV - 답글
Hello,
Thank you so much for the guide.
Have a question though, is the following battery compatible for Lenovo Flex 5 1570 (Type 80XB): https://www.ebuyindia.in/products/origin...
Appreciate your help.
Anshul Gandhi - 답글
I bought this battery to replace my old failed battery. The installation went very well. But I soon noticed that the battery and the charging adaptor were getting extremely hot every time I plugged it in. After 1 month the laptop stopped completely. There was absolutely no issues with the laptop before except the battery.
I would never go for an iFixit battery again.
Pragha - 답글
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 70
30일 전: 275
전체 시간: 23,858
