주요 콘텐츠로 건너뛰기
Lenovo Ideapad 320-17IKB Battery Replacement
필요한 것
  1. Lenovo Ideapad 320-17IKB Battery Replacement, Back Panel: 1 단계, 이미지 1/1
    • Turn off and unplug the computer.
    • Flip the laptop over so that the back panel is facing upwards.
  2. Lenovo Ideapad 320-17IKB Battery Replacement: 2 단계, 이미지 1/2 Lenovo Ideapad 320-17IKB Battery Replacement: 2 단계, 이미지 2/2
    • Remove fourteen 7mm Phillips #00 screws from the back panel.
  3. Lenovo Ideapad 320-17IKB Battery Replacement: 3 단계, 이미지 1/1
    • Carefully remove the optical drive by pulling the bezel away from the laptop.
  4. Lenovo Ideapad 320-17IKB Battery Replacement: 4 단계, 이미지 1/2 Lenovo Ideapad 320-17IKB Battery Replacement: 4 단계, 이미지 2/2
    • Use your fingers or an opening tool to gently remove the back panel from the bottom of the laptop.
    • Lay both sides of the laptop next to each other.
  5. Lenovo Ideapad 320-17IKB Battery Replacement, Battery: 5 단계, 이미지 1/2 Lenovo Ideapad 320-17IKB Battery Replacement, Battery: 5 단계, 이미지 2/2
    • Remove five 7mm Phillips #0 screws from the battery holder.
  6. Lenovo Ideapad 320-17IKB Battery Replacement: 6 단계, 이미지 1/2 Lenovo Ideapad 320-17IKB Battery Replacement: 6 단계, 이미지 2/2
    • Pinch the connecting cord with one hand and pry the battery connector with the other hand, while gently pulling the connector straight out and towards the bottom edge of the base.
    • When removing the battery, use care to keep it flat and do not open the battery because it can result in fire or explosion.
결론
다른 2명이 해당 안내서를 완성하였습니다.
a1235
회원 가입일: 09/02/19
611 평판
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 33
전체 시간: 4,410
