주요 콘텐츠로 건너뛰기
Lenovo Legion 5 Pro 16ACH6H Battery Replacement
필요한 것
  1. Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Back cover removal: 1 단계, 이미지 1/2 Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Back cover removal: 1 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the following ten screws securing the back cover to frame:
    • Six 12.7 mm PH00 screws
    • Four 4.2 mm PH00 screws
  2. Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Release the front clips: 2 단계, 이미지 1/3 Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Release the front clips: 2 단계, 이미지 2/3 Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Release the front clips: 2 단계, 이미지 3/3
    • Insert the rounded edge of an opening pick between the back cover and the frame in the lower right corner.
  3. Lenovo Legion 5 Pro 16ACH6H Battery Replacement: 3 단계, 이미지 1/3 Lenovo Legion 5 Pro 16ACH6H Battery Replacement: 3 단계, 이미지 2/3 Lenovo Legion 5 Pro 16ACH6H Battery Replacement: 3 단계, 이미지 3/3
    • Angle the pick to about 45˚.
    • Slide the pick along the front edge to release the clips securing the back cover to the frame.
  4. Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Release the right clips: 4 단계, 이미지 1/3 Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Release the right clips: 4 단계, 이미지 2/3 Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Release the right clips: 4 단계, 이미지 3/3
    • Insert the rounded edge of an opening pick between the back cover and the frame on the right edge.
    • Angle the pick to about 30˚ and slide down the right edge until you reach the plastic vents on the side.
  5. Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Release the left clips: 5 단계, 이미지 1/3 Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Release the left clips: 5 단계, 이미지 2/3 Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Release the left clips: 5 단계, 이미지 3/3
    • Repeat the same procedure on the left edge to release the clips.
  6. Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Release the right vent clips: 6 단계, 이미지 1/3 Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Release the right vent clips: 6 단계, 이미지 2/3 Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Release the right vent clips: 6 단계, 이미지 3/3
    • Position the laptop vertically so you can easily access the plastic vents.
    • Slide the rounded edge of an opening pick between the frame and the plastic vents on the right side near the USB-A port.
    • Rotate the pick so that it is positioned on top of the plastic vents.
  7. Lenovo Legion 5 Pro 16ACH6H Battery Replacement: 7 단계, 이미지 1/2 Lenovo Legion 5 Pro 16ACH6H Battery Replacement: 7 단계, 이미지 2/2
    • Push the pick between the frame and plastic vents.
    • Slide the pick along the top edge of the plastic vents to release the clips.
  8. Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Release the left vent clips: 8 단계, 이미지 1/3 Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Release the left vent clips: 8 단계, 이미지 2/3 Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Release the left vent clips: 8 단계, 이미지 3/3
    • Slide the rounded edge of an opening pick between the frame and the plastic vents on the left side near the USB-C port.
  9. Lenovo Legion 5 Pro 16ACH6H Battery Replacement: 9 단계, 이미지 1/2 Lenovo Legion 5 Pro 16ACH6H Battery Replacement: 9 단계, 이미지 2/2
  10. Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Remove the back cover: 10 단계, 이미지 1/3 Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Remove the back cover: 10 단계, 이미지 2/3 Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Remove the back cover: 10 단계, 이미지 3/3
    • Lift the back cover up and remove it from the chassis.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  11. Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Disconnect the battery: 11 단계, 이미지 1/3 Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Disconnect the battery: 11 단계, 이미지 2/3 Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Disconnect the battery: 11 단계, 이미지 3/3
    • Use the pointed end of a spudger to push each side of the battery connector to loosen it.
  12. Lenovo Legion 5 Pro 16ACH6H Battery Replacement: 12 단계, 이미지 1/2 Lenovo Legion 5 Pro 16ACH6H Battery Replacement: 12 단계, 이미지 2/2
    • Use the flat end of a spudger to push out and disconnect battery cable.
  13. Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Right SSD removal: 13 단계, 이미지 1/2 Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Right SSD removal: 13 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the three 5.1 mm PH00 screws securing the right SSD shield to the motherboard.
    • During reassembly, make sure the hole on the top of the shield aligns with the post on the chassis.
  14. Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Remove the SSD shield: 14 단계, 이미지 1/3 Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Remove the SSD shield: 14 단계, 이미지 2/3 Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Remove the SSD shield: 14 단계, 이미지 3/3
    • Grab the SSD shield and lift up to remove it.
  15. Lenovo Legion 5 Pro 16ACH6H Battery Replacement: 15 단계, 이미지 1/2 Lenovo Legion 5 Pro 16ACH6H Battery Replacement: 15 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the 2.6 mm PH1 screw securing the SSD to the motherboard.
    • The SSD will spring up to about 30˚ when the screw is removed.
  16. Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Remove the right SSD: 16 단계, 이미지 1/3 Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Remove the right SSD: 16 단계, 이미지 2/3 Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Remove the right SSD: 16 단계, 이미지 3/3
    • Grip the edges of the SSD near the screw indent.
    • Gently pull to remove the SSD.
  17. Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Unfasten the battery: 17 단계, 이미지 1/1
    • Use your Phillips screwdriver to remove the six 5.1 mm-long screws securing the battery.
  18. Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Remove the battery: 18 단계, 이미지 1/2 Lenovo Legion 5 Pro 16ACH6H Battery Replacement, Remove the battery: 18 단계, 이미지 2/2
    • Remove the battery from its recess.
결론
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo Legion answers community for help.
Clay Eickemeyer
회원 가입일: 09/19/22
70,411 평판
안내서 453개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 18,103개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 49
30일 전: 231
전체 시간: 4,048
