소개
Follow this guide to remove, replace, or upgrade the LPCAMM2 (Low Power Compression-Attached Memory Module) in your Lenovo ThinkPad P1 (Gen 7) laptop.
The ThinkPad P1 Gen 7 uses LPDDR5X memory in its LPCAMM2.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
필요한 것
Shut down your laptop (don't just put it in sleep mode) and disconnect all cables.
Flip the laptop upside-down, and rotate it so the screen hinge faces towards you.
Use a Phillips screwdriver to loosen the six captive screws securing the base cover.
Press the tip of an opening pick into the seam between the base cover and the bottom-left corner of the frame (near the screen hinge).
Pivot the pick down and slide it around the corner to release the clips.
Press the tip of an opening pick into the seam between the base cover and the bottom-right corner of the frame (near the screen hinge).
Grasp the base cover along the screen hinge edge and pull up to loosen the cover.
Use a Phillips screwdriver to loosen the six captive screws securing the battery.
Use a Phillips screwdriver to loosen the three captive screws securing the LPCAMM2 bracket.
Grab the edges of the LPCAMM2 bracket and lift straight up to remove it.
Grasp the compression connector by the edges and lift straight up to remove it.
Grip the LPCAMM2 by its edges, and lay it on top of the compression connector.
Lay the bracket on top of the LPCAMM2 and align it using the screw holes.
Align the bottom edge of the battery to its recess.
Lay the battery into its recess and press down gently.
Use a Phillips screwdriver to tighten the six captive screws to re-secure the battery.
Align the base cover to the chassis and lay it in place.
Press firmly along the sides and corners of the base cover to reengage the clips.
Use a Phillips screwdriver to tighten the six captive screws to re-secure the base cover.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 한 개
Thank you, iFixit, for the detailed, easy-to-understand repair guide on the new, revolutionary LPCAMM2 memory on the ThinkPad P1 Gen 7.
