주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo ThinkPad P50 Display Replacement
필요한 것
  1. Lenovo ThinkPad P50 Display Replacement, Battery: 1 단계, 이미지 2개 중 1개 Lenovo ThinkPad P50 Display Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Slide the battery latch to the left to unlock it and remove the battery.
    댓글 쓰기
  2. Lenovo ThinkPad P50 Display Replacement, Bottom case screws: 2 단계, 이미지 1개 중 1개
    • Loosen the six 12.6 mm captive screws that secure the lower case with the Phillips #00 screwdriver.
    • The screws will not come all the way out; do not attempt to remove them from the case.
    • Pull up the notch with your fingernail or a spudger.
    댓글 쓰기
  3. Lenovo ThinkPad P50 Display Replacement, Bottom case: 3 단계, 이미지 2개 중 1개 Lenovo ThinkPad P50 Display Replacement, Bottom case: 3 단계, 이미지 2개 중 2개
    • Lift the lower case up and off of the chassis.
    댓글 쓰기
  4. Lenovo ThinkPad P50 Display Replacement, Display: 4 단계, 이미지 2개 중 1개 Lenovo ThinkPad P50 Display Replacement, Display: 4 단계, 이미지 2개 중 2개
    • Use an iFixit opening pick to carefully remove the plastic bezel from the front of the display.
    • There are clips beneath the trim that need to be carefully detached.
    • Avoid using metal tools, as they can damage the plastic components.
    댓글 쓰기
  5. Lenovo ThinkPad P50 Display Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the four 2.5 mm screws located along the corners with a Phillips #00 screwdriver.
    댓글 쓰기
  6. Lenovo ThinkPad P50 Display Replacement: 6 단계, 이미지 3개 중 1개 Lenovo ThinkPad P50 Display Replacement: 6 단계, 이미지 3개 중 2개 Lenovo ThinkPad P50 Display Replacement: 6 단계, 이미지 3개 중 3개
    • Carefully tilt the screen forward and lay it face down on the keyboard, making sure not to strain or damage the cable still attached to it.
    • Display (sometimes called eDP cables in laptops) and camera cable connectors often have a small metal buckle running around the socket, locking them in place. The connectors are typically wide and may have tape attached to the buckle.
    • Gently push the tip of a spudger under the metal buckle to unclip it, then swing it over the socket.
    • Hold the buckle and cable together and gently pull the connector straight out of its socket.
    댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Sara Richardson
회원 가입일: 03/21/25
609 평판
안내서 5개를 작성함
UMass Dartmouth, Team 3-1, Botvin Spring 2025 UMass Dartmouth, Team 3-1, Botvin Spring 2025 회원
UMASSD-BOTVIN-S25S3G1
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 16
지난 30일: 109
전체 시간: 611
