주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T460 External Battery Replacement
필요한 것
  1. Lenovo ThinkPad T460 External Battery Replacement, External Battery: 1 단계, 이미지 1/3 Lenovo ThinkPad T460 External Battery Replacement, External Battery: 1 단계, 이미지 2/3 Lenovo ThinkPad T460 External Battery Replacement, External Battery: 1 단계, 이미지 3/3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T460 External Battery Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad T460 External Battery Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad T460 External Battery Replacement: 2 단계, 이미지 3/3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
Kristen Gismondi
회원 가입일: 11/12/14
82,272 평판
안내서 200개 작성하였습니다
iFixit iFixit 회원
Staff
136 회원들
안내서 17,292개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 15
30일 전: 49
전체 시간: 1,081
