주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T470 External Battery Replacement
필요한 것
  1. Lenovo ThinkPad T470 External Battery Replacement, External Battery: 1 단계, 이미지 1/3 Lenovo ThinkPad T470 External Battery Replacement, External Battery: 1 단계, 이미지 2/3 Lenovo ThinkPad T470 External Battery Replacement, External Battery: 1 단계, 이미지 3/3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T470 External Battery Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad T470 External Battery Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad T470 External Battery Replacement: 2 단계, 이미지 3/3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 2명이 해당 안내서를 완성하였습니다.
Kristen Gismondi
회원 가입일: 11/12/14
85,251 평판
안내서 215개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 18,085개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 30
30일 전: 92
전체 시간: 2,792
