주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T490s Battery Replacement
필요한 것
  1. Lenovo ThinkPad T490s Battery Replacement, Loosen the back screws: 1 단계, 이미지 1/2 Lenovo ThinkPad T490s Battery Replacement, Loosen the back screws: 1 단계, 이미지 2/2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use your Phillips #1 screwdriver to fully loosen the five screws on the back cover.
    • These screws are captive—they won't come out after being unscrewed.
  2. Lenovo ThinkPad T490s Battery Replacement, Release the clips: 2 단계, 이미지 1/2 Lenovo ThinkPad T490s Battery Replacement, Release the clips: 2 단계, 이미지 2/2
    • Orient your laptop so that the screen's silver hinges are closest to you.
    • Insert an opening pick between the back cover and the device body near a hinge corner.
    • Pry upward to release the clips holding the cover. Listen for a loud click when each clip releases.
  3. Lenovo ThinkPad T490s Battery Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad T490s Battery Replacement: 3 단계, 이미지 2/2
    • Insert your opening pick between the cover and the device body at the other hinge corner.
    • Pry upward to release additional retaining clips.
  4. Lenovo ThinkPad T490s Battery Replacement, Remove the back cover: 4 단계, 이미지 1/3 Lenovo ThinkPad T490s Battery Replacement, Remove the back cover: 4 단계, 이미지 2/3 Lenovo ThinkPad T490s Battery Replacement, Remove the back cover: 4 단계, 이미지 3/3
    • Grab the front edge of the cover and lift it away from you.
    • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
  5. Lenovo ThinkPad T490s Battery Replacement, Disconnect the battery cable: 5 단계, 이미지 1/2 Lenovo ThinkPad T490s Battery Replacement, Disconnect the battery cable: 5 단계, 이미지 2/2
    • Grab the battery pull-tab at the head of the connector.
    • Pull the connector out of its socket in the direction of the cable.
  6. Lenovo ThinkPad T490s Battery Replacement, Unfasten the battery: 6 단계, 이미지 1/2 Lenovo ThinkPad T490s Battery Replacement, Unfasten the battery: 6 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the five 5.2 mm-long screws securing the battery.
  7. Lenovo ThinkPad T490s Battery Replacement, Remove the battery: 7 단계, 이미지 1/3 Lenovo ThinkPad T490s Battery Replacement, Remove the battery: 7 단계, 이미지 2/3 Lenovo ThinkPad T490s Battery Replacement, Remove the battery: 7 단계, 이미지 3/3
    • Lift the battery straight out of its recess and remove it.
결론
For optimal performance, calibrate your newly installed battery after completing this guide.
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
129,330 평판
안내서 600개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 18,085개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 16
7일 전: 87
30일 전: 358
전체 시간: 5,774
