주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo ThinkPad T495 RAM Replacement
필요한 것
  1. Lenovo ThinkPad T495 RAM Replacement, Baseplate: 1 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to loosen the six captive screws.
    • The screws will stay attached to the back cover as you lift it off; do not attempt to remove them.
    댓글 쓰기
  2. Lenovo ThinkPad T495 RAM Replacement: 2 단계, 이미지 1개 중 1개
    • Use an iFixit opening tool to start prying under one of the hinges, between the baseplate and chassis, and work your way around the perimeter until the baseplate releases.
    • Lift off the baseplate.
    댓글 쓰기
  3. Lenovo ThinkPad T495 RAM Replacement, RAM: 3 단계, 이미지 2개 중 1개 Lenovo ThinkPad T495 RAM Replacement, RAM: 3 단계, 이미지 2개 중 2개
    • Lift the black flap to expose the RAM.
    댓글 쓰기
  4. Lenovo ThinkPad T495 RAM Replacement: 4 단계, 이미지 3개 중 1개 Lenovo ThinkPad T495 RAM Replacement: 4 단계, 이미지 3개 중 2개 Lenovo ThinkPad T495 RAM Replacement: 4 단계, 이미지 3개 중 3개
    • Use your fingers to gently pull the two arms on each side horizontally until the RAM springs up.
    • Grip the RAM between your fingers and pull it gently until it releases from the port.
    • When reinstalling the RAM, push it down vertically, toward the motherboard, until the arms audibly click, securing the RAM in place.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Christian Taylor
회원 가입일: 03/28/22
706 평판
안내서 6개를 작성함
UMass Dartmouth, Team 1-6, Petersen Spring 2022 UMass Dartmouth, Team 1-6, Petersen Spring 2022 회원
UMASSD-PETERSEN-S22S1G6
3 회원들
안내서 8개를 작성함
2가이드 댓글
Hi, can we disable the onboard RAM from BIOS or any tool from the OS?
Sajay Sunny - 답글 공유
Big problem here. You cannot remove the RAM that comes with the laptop. The instructions above say "Use your fingers to gently pull the two arms on each side horizontally until the RAM springs up." No, the RAM does not spring up on my T495 because it is soldered! By the time I realized that, I had nearly broken one of the RAM-holding arms. The T495 comes with two RAM slots. On my laptop, one slot had an 8 GM RAM module that came with the laptop. After realizing it cannot be removed, I put in a new 16 GB RAM module on top of the old one. The new module is now held in place by only one of the arms. The other one is dislocated because of the fool I was in trying to pull the arm until the old RAM sprang up. It is soldered, as I learned the hard way.
sysmulch - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 32
지난 30일: 129
전체 시간: 9,592
