주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T580 Cooling Fan Replacement
필요한 것
  1. Lenovo ThinkPad T580 Cooling Fan Replacement, External Battery: 1 단계, 이미지 1/3 Lenovo ThinkPad T580 Cooling Fan Replacement, External Battery: 1 단계, 이미지 2/3 Lenovo ThinkPad T580 Cooling Fan Replacement, External Battery: 1 단계, 이미지 3/3
    • Slide the switch on the left side of the battery to the left.
  2. Lenovo ThinkPad T580 Cooling Fan Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad T580 Cooling Fan Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad T580 Cooling Fan Replacement: 2 단계, 이미지 3/3
    • Slide the switch on the right side of the battery to the right while applying upward pressure on the battery.
  3. Lenovo ThinkPad T580 Cooling Fan Replacement: 3 단계, 이미지 1/3 Lenovo ThinkPad T580 Cooling Fan Replacement: 3 단계, 이미지 2/3 Lenovo ThinkPad T580 Cooling Fan Replacement: 3 단계, 이미지 3/3
    • Pull the battery directly out of the socket
  4. Lenovo ThinkPad T580 Cooling Fan Replacement, Bottom Case: 4 단계, 이미지 1/2 Lenovo ThinkPad T580 Cooling Fan Replacement, Bottom Case: 4 단계, 이미지 2/2
    • Using a Phillips #00 screwdriver, unscrew the eight 3.3 mm captive screws on the bottom of the laptop.
    • The "captive" screws will not come out of the case.
  5. Lenovo ThinkPad T580 Cooling Fan Replacement: 5 단계, 이미지 1/3 Lenovo ThinkPad T580 Cooling Fan Replacement: 5 단계, 이미지 2/3 Lenovo ThinkPad T580 Cooling Fan Replacement: 5 단계, 이미지 3/3
    • Run a Jimmy along the crease of the computer all the way around, twisting it periodically to disengage the clips.
  6. Lenovo ThinkPad T580 Cooling Fan Replacement: 6 단계, 이미지 1/3 Lenovo ThinkPad T580 Cooling Fan Replacement: 6 단계, 이미지 2/3 Lenovo ThinkPad T580 Cooling Fan Replacement: 6 단계, 이미지 3/3
    • Once all the clips are released, remove the bottom cover.
    • You may need to jiggle the case slightly to release the clips around the external battery bay.
  7. Lenovo ThinkPad T580 Cooling Fan Replacement, Cooling Fan: 7 단계, 이미지 1/2 Lenovo ThinkPad T580 Cooling Fan Replacement, Cooling Fan: 7 단계, 이미지 2/2
    • Unplug the cooling fan's cable from the the motherboard.
  8. Lenovo ThinkPad T580 Cooling Fan Replacement: 8 단계, 이미지 1/3 Lenovo ThinkPad T580 Cooling Fan Replacement: 8 단계, 이미지 2/3 Lenovo ThinkPad T580 Cooling Fan Replacement: 8 단계, 이미지 3/3
    • Using a Phillips #00 screwdriver, unscrew five 4.6 mm screws fastening the fan and cooling pipe.
    • The screws are set in the plastic and are not able to be removed from the fan parts.
  9. Lenovo ThinkPad T580 Cooling Fan Replacement: 9 단계, 이미지 1/1
    • Remove the cooling fan directly upwards from the core.
    • Be sure to clean and replace any thermal paste on the heatsink and CPU before reassembling. You can use our How to Apply Thermal Paste guide if you need any help!
결론
Ben Elkayam
회원 가입일: 01/23/20
978 평판
안내서 8개 작성하였습니다
Cal Poly, Team S18-G6, White Winter 2020 Cal Poly, Team S18-G6, White Winter 2020 회원
CPSU-WHITE-W20S18G6
4 회원들
안내서 24개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 51
전체 시간: 2,439
