주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo ThinkPad X100e Keyboard Replacement
필요한 것
  1. Lenovo ThinkPad X100e Keyboard Replacement, Keyboard: 1 단계, 이미지 2개 중 1개 Lenovo ThinkPad X100e Keyboard Replacement, Keyboard: 1 단계, 이미지 2개 중 2개
    • Remove battery by flipping the laptop over and pressing the two tabs inward and place aside
    • For detailed instructions on how to remove a battery, please view the (battery replacement link).
    댓글 쓰기
  2. Lenovo ThinkPad X100e Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Using a magnetic screwdriver fit with a PH0 bit, unscrew the first 7 screws on the back of the device the screws should be bound to the panel.
    • Pry up the back panel and set it aside with the battery.
    댓글 쓰기
  3. Lenovo ThinkPad X100e Keyboard Replacement: 3 단계, 이미지 2개 중 1개 Lenovo ThinkPad X100e Keyboard Replacement: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    • Remove the two retaining screws where the battery is located. Set the two screws aside on the magnetic mat and label one square “battery compartment screws (2)” like so.
    댓글 쓰기
  4. Lenovo ThinkPad X100e Keyboard Replacement: 4 단계, 이미지 3개 중 1개 Lenovo ThinkPad X100e Keyboard Replacement: 4 단계, 이미지 3개 중 2개 Lenovo ThinkPad X100e Keyboard Replacement: 4 단계, 이미지 3개 중 3개
    • Turn the device over and open the cover.
    • Using the prying tool, pry the keyboard up from the top left side of the keyboard then work your way all the way around the keyboard until it is only attached by two ribbon wires.
    댓글 쓰기
  5. Lenovo ThinkPad X100e Keyboard Replacement: 5 단계, 이미지 2개 중 1개 Lenovo ThinkPad X100e Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • using the pryer, pull the little black tab above the blue ribbon up, now you should be able to pull the wires straight out and fully remove your keyboard.
    댓글 쓰기
  6. Lenovo ThinkPad X100e Keyboard Replacement: 6 단계, 이미지 1개 중 1개
    • Get your replacement keyboard or reinstall your keyboard to see if it was just a faulty connection in the device.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jacquelyn Nguyen
회원 가입일: 02/08/18
199 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 15
전체 시간: 1,433
