주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo ThinkPad X100e Screen Replacement
필요한 것
  1. Lenovo ThinkPad X100e Screen Replacement, Screen: 1 단계, 이미지 2개 중 1개 Lenovo ThinkPad X100e Screen Replacement, Screen: 1 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Spudger
    $2.99
    • Use a Spudger tool to remove the screw covers on each side of the screen.
    • Be sure not to lose screw covers.
    댓글 쓰기
  2. Lenovo ThinkPad X100e Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Using a magnetic screwdriver fit with a PH0 Bit, unscrew the two screws and carefully set the aside.
    댓글 쓰기
  3. Lenovo ThinkPad X100e Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Pry open the bezel carefully with the spudger tool.
    • You will want to do this until the frame is completely off.
    댓글 쓰기
  4. Lenovo ThinkPad X100e Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Remove all exposed screws and carefully set them aside. There should be 6 visible screws.
    • Be sure to set the screws aside on the magnetic mat.
    댓글 쓰기
  5. Lenovo ThinkPad X100e Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the screen up carefully, and remove the screws on both sides of the panel. There should be 4 screws.
    • The other two screws are located in the exact place on the other side.
    • Don't forget to place the screws on the magnetic mat, separate from other screws.
    댓글 쓰기
  6. Lenovo ThinkPad X100e Screen Replacement: 6 단계, 이미지 2개 중 1개 Lenovo ThinkPad X100e Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the connector located at the very top of the screen beside the webcam.
    • To remove the connector, simply pull the connector out.
    댓글 쓰기
  7. Lenovo ThinkPad X100e Screen Replacement: 7 단계, 이미지 1개 중 1개
    • Fold the panel over until a strip of black tape is visible.
    • Peel the tape down until you get to the base.
    댓글 쓰기
  8. Lenovo ThinkPad X100e Screen Replacement: 8 단계, 이미지 2개 중 1개 Lenovo ThinkPad X100e Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Peel the piece of transparent tape back.
    • At this point there should be some exposed wires underneath the tape.
    댓글 쓰기
  9. Lenovo ThinkPad X100e Screen Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the connector carefully with the spudger tool.
    댓글 쓰기
  10. Lenovo ThinkPad X100e Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the black tape fully.
    • Now your device is ready for a new panel.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Orly Guerra
회원 가입일: 02/08/18
448 평판
안내서 2개를 작성함
1가이드 댓글
What can be used as a replacement screen, as it's listed not for sale?
Keith Bowe - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 42
전체 시간: 1,330
