주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo ThinkPad X140e Keyboard Replacement
필요한 것
  1. Lenovo ThinkPad X140e Keyboard Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Set the laptop facing you with the screen open.
    댓글 쓰기
  2. Lenovo ThinkPad X140e Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Lenovo ThinkPad X140e Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Using a small plastic opening tool, pry off the keyboard starting at a point closest to you and working around the perimeter.
    댓글 쓰기
  3. Lenovo ThinkPad X140e Keyboard Replacement: 3 단계, 이미지 3개 중 1개 Lenovo ThinkPad X140e Keyboard Replacement: 3 단계, 이미지 3개 중 2개 Lenovo ThinkPad X140e Keyboard Replacement: 3 단계, 이미지 3개 중 3개
    • Flip up the ZIF connector that is holding the small ribbon cable in place.
    • Proceed to pull out the small ribbon cable
    댓글 쓰기
  4. Lenovo ThinkPad X140e Keyboard Replacement: 4 단계, 이미지 3개 중 1개 Lenovo ThinkPad X140e Keyboard Replacement: 4 단계, 이미지 3개 중 2개 Lenovo ThinkPad X140e Keyboard Replacement: 4 단계, 이미지 3개 중 3개
    • Flip up the ZIF connector that is holding the larger ribbon cable in place.
    • Proceed to pull out the large ribbon cable.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
kevin hull
회원 가입일: 10/05/16
219 평판
안내서 2개를 작성함
Cal Poly, Team 20-5, Livingston Fall 2016 Cal Poly, Team 20-5, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S20G5
4 회원들
안내서 5개를 작성함
4가이드 댓글
how can I buy a keyboard for my lenovo thinkpad x140e laptop?
Bryan - 답글 공유
The keyboard for the X140e is the same as the one for the X130e and the X131e and the X121e.
It is FRU 04y0379
Buy the keyboard on eBay.
atexit8 - 답글 공유
Just as a note, there are two screws that keep that keyboard held in place. You need to remove the back panel and take out those two screws, otherwise you’re going to have a tough time. Also, you really don’t need the pry tool, once those screws are out, the keyboard slides off. The rest of the process is spot on.
Jeffrey Chocklette - 답글 공유
Don’t forget the screws, otherwise you will never get the keyboard off or worse damage it during removal
celticxxtwin - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 46
전체 시간: 2,281
