주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X270 External Battery Replacement
필요한 것
  1. Lenovo ThinkPad X270 External Battery Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 1/2 Lenovo ThinkPad X270 External Battery Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2/2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Lenovo ThinkPad X270 External Battery Replacement, Battery information: 2 단계, 이미지 1/2 Lenovo ThinkPad X270 External Battery Replacement, Battery information: 2 단계, 이미지 2/2
    • Lay your laptop upside down to access the external battery.
    • Two sliding tabs secure the battery.
  3. Lenovo ThinkPad X270 External Battery Replacement, Release the left tab: 3 단계, 이미지 1/2 Lenovo ThinkPad X270 External Battery Replacement, Release the left tab: 3 단계, 이미지 2/2
    • Slide the left tab, labeled 1, to the unlocked position—it'll click into place and release the left side of the battery.
  4. Lenovo ThinkPad X270 External Battery Replacement, Remove the battery: 4 단계, 이미지 1/3 Lenovo ThinkPad X270 External Battery Replacement, Remove the battery: 4 단계, 이미지 2/3 Lenovo ThinkPad X270 External Battery Replacement, Remove the battery: 4 단계, 이미지 3/3
    • Hold the right tab, labeled 2, in the unlocked position and slide the battery out of its recess.
    • During reassembly, slide the battery into its recess until both tabs engage.
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
결론
Check your repair by running hardware tests with Lenovo Diagnostics.
For optimal performance, calibrate your newly installed battery after completing this guide.
다른 한 분이 해당 안내서를 완성하였습니다.
Spencer Day
회원 가입일: 09/14/22
54,804 평판
안내서 407개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,277개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 42
전체 시간: 449
