주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo ThinkPad X280 Fingerprint Scanner Replacement
필요한 것
  1. Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • To begin, ensure that the device is completely powered off and not connected to an energy supply.
    • Close the device and flip it over to expose the back panel.
    댓글 쓰기
  2. Lenovo ThinkPad X280  Fingerprint Scanner Replacement: 2 단계, 이미지 2개 중 1개 Lenovo ThinkPad X280  Fingerprint Scanner Replacement: 2 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to unscrew the five captive screws on the back panel until a small pop is heard.
    • These are captive screws and do not come out completely.
    댓글 쓰기
  3. Lenovo ThinkPad X280  Fingerprint Scanner Replacement: 3 단계, 이미지 2개 중 1개 Lenovo ThinkPad X280  Fingerprint Scanner Replacement: 3 단계, 이미지 2개 중 2개
    • Gently wedge an opening tool or spudger under the back panel, and loosen the clips around the perimeter until the back panel comes off.
    • Remove the back cover.
    댓글 쓰기
  4. Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Battery: 4 단계, 이미지 3개 중 1개 Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Battery: 4 단계, 이미지 3개 중 2개 Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Battery: 4 단계, 이미지 3개 중 3개
    • Using the Phillips #1 screwdriver, remove the four 5 mm screws that are holding the battery down.
    • Remove the battery.
    댓글 쓰기
  5. Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Fingerprint Scanner: 5 단계, 이미지 3개 중 1개 Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Fingerprint Scanner: 5 단계, 이미지 3개 중 2개 Lenovo ThinkPad X280  Fingerprint Scanner Replacement, Fingerprint Scanner: 5 단계, 이미지 3개 중 3개
    • Using a Phillips #1 screwdriver, remove one 5 mm screw from the fingerprint sensor.
    • Remove the metal plate covering the sensor.
    댓글 쓰기
  6. Lenovo ThinkPad X280  Fingerprint Scanner Replacement: 6 단계, 이미지 2개 중 1개 Lenovo ThinkPad X280  Fingerprint Scanner Replacement: 6 단계, 이미지 2개 중 2개
    • Using the black spudger tool, flip up the small hinged locking flap connected to the motherboard.
    • Gently pull the cable out of the connection site.
    댓글 쓰기
  7. Lenovo ThinkPad X280  Fingerprint Scanner Replacement: 7 단계, 이미지 1개 중 1개
    • Remove fingerprint scanner and metal covering from device.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jordan Wooten
회원 가입일: 09/05/21
636 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 26
전체 시간: 1,916
