주요 콘텐츠로 건너뛰기
Lenovo ThinkPad X395 Battery Replacement
필요한 것
  1. Lenovo ThinkPad X395 Battery Replacement, Loosen the back screws: 1 단계, 이미지 1/2 Lenovo ThinkPad X395 Battery Replacement, Loosen the back screws: 1 단계, 이미지 2/2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips #1 screwdriver to fully loosen the five screws on the back cover.
    • These are captive screws—they won't come out after being loosened.
  2. Lenovo ThinkPad X395 Battery Replacement, Release the clips: 2 단계, 이미지 1/2 Lenovo ThinkPad X395 Battery Replacement, Release the clips: 2 단계, 이미지 2/2
    • Orient your laptop so that the screen's silver hinges are closest to you.
    • Insert an opening pick between the back cover and the device body near a hinge corner.
    • Pry upward to release the retaining clips. Listen for a loud click when each clip releases.
  3. Lenovo ThinkPad X395 Battery Replacement: 3 단계, 이미지 1/2 Lenovo ThinkPad X395 Battery Replacement: 3 단계, 이미지 2/2
    • Insert the opening pick between the back cover and the device body at the other hinge corner.
    • Pry upward on the cover to release additional clips.
  4. Lenovo ThinkPad X395 Battery Replacement, Remove the back cover: 4 단계, 이미지 1/3 Lenovo ThinkPad X395 Battery Replacement, Remove the back cover: 4 단계, 이미지 2/3 Lenovo ThinkPad X395 Battery Replacement, Remove the back cover: 4 단계, 이미지 3/3
    • Lift and remove the cover up from the laptop, starting with the edge nearest to you.
    • Shift the cover side to side if the center clip feels stuck.
    • The cover will hinge open before completely separating from the rest of the laptop.
  5. Lenovo ThinkPad X395 Battery Replacement, Disconnect the battery cable: 5 단계, 이미지 1/2 Lenovo ThinkPad X395 Battery Replacement, Disconnect the battery cable: 5 단계, 이미지 2/2
    • Grab the battery pull-tab on the head of the connector.
    • Pull the connector out of its socket in the direction of the cable.
  6. Lenovo ThinkPad X395 Battery Replacement, Unfasten the battery: 6 단계, 이미지 1/1
    • Use your Phillips screwdriver to remove the four 5.3 mm-long screws securing the battery.
  7. Lenovo ThinkPad X395 Battery Replacement, Remove the battery: 7 단계, 이미지 1/2 Lenovo ThinkPad X395 Battery Replacement, Remove the battery: 7 단계, 이미지 2/2
    • Remove the battery from its recess.
결론
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo ThinkPad answers community for help.
Clay Eickemeyer
회원 가입일: 09/19/22
69,496 평판
안내서 453개 작성하였습니다
iFixit iFixit 회원
Staff
141 회원들
안내서 17,895개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 69
30일 전: 259
전체 시간: 2,639
