주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo Thinkpad T450s RAM Replacement
필요한 것
    1. Lenovo Thinkpad T450s RAM Replacement, Battery: 1 단계, 이미지 2개 중 1개 Lenovo Thinkpad T450s RAM Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Turn off device before starting
      • Flip the laptop upside down so you have access to the battery.
      댓글 쓰기
    2. Lenovo Thinkpad T450s RAM Replacement: 2 단계, 이미지 1개 중 1개
      • Slide lock button 1 to the unlock position and gently slide away from your body.
      댓글 쓰기
    3. Lenovo Thinkpad T450s RAM Replacement: 3 단계, 이미지 2개 중 1개 Lenovo Thinkpad T450s RAM Replacement: 3 단계, 이미지 2개 중 2개
      • Slide lock button 2 to the unlock position and continue gently sliding until the battery is removed.
      댓글 쓰기
    1. Lenovo Thinkpad T450s RAM Replacement, Lenovo Thinkpad T450s Bottom Panel Removal: 4 단계, 이미지 3개 중 1개 Lenovo Thinkpad T450s RAM Replacement, Lenovo Thinkpad T450s Bottom Panel Removal: 4 단계, 이미지 3개 중 2개 Lenovo Thinkpad T450s RAM Replacement, Lenovo Thinkpad T450s Bottom Panel Removal: 4 단계, 이미지 3개 중 3개
      • Flip the device over and lay it down with the underside facing upwards.
      • Unscrew all 8 screws. While they should not come out completely, in some cases, the plastic retaining washers may come off of one or more of the screws, allowing them to come out completely. - should this happen, look for a loose, tiny black plastic washer once the case is open. It's possible, in some cases, to reattach the retaining washer.
      댓글 쓰기
    2. Lenovo Thinkpad T450s RAM Replacement: 5 단계, 이미지 2개 중 1개 Lenovo Thinkpad T450s RAM Replacement: 5 단계, 이미지 2개 중 2개
      • Pry the bottom from the computer until it pops out.
      • In some cases, the vented side of the case may cling to the heat sink; appears to be adhesive. Take care when separating.
      댓글 쓰기
    1. Lenovo Thinkpad T450s RAM Replacement, RAM: 6 단계, 이미지 3개 중 1개 Lenovo Thinkpad T450s RAM Replacement, RAM: 6 단계, 이미지 3개 중 2개 Lenovo Thinkpad T450s RAM Replacement, RAM: 6 단계, 이미지 3개 중 3개
      • Pull one side of the prong that is holding the RAM in place
      댓글 쓰기
    2. Lenovo Thinkpad T450s RAM Replacement: 7 단계, 이미지 1개 중 1개
      • Pull the other side prong until the RAM pops up.
      댓글 쓰기
    3. Lenovo Thinkpad T450s RAM Replacement: 8 단계, 이미지 2개 중 1개 Lenovo Thinkpad T450s RAM Replacement: 8 단계, 이미지 2개 중 2개
      • Pull the RAM out of the device
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Hayden Hausman
회원 가입일: 01/17/19
637 평판
안내서 6개를 작성함
1가이드 댓글
My t450s comes with an internal battery. The comment on this guide records the process for disabling the internal battery temporarily.
I also used this guide from Lenovo as I found removing the back plate rather difficult.
ray beats - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 52
전체 시간: 5,796
