주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo V14-ADA Keyboard Key Replacement
필요한 것
    1. Lenovo V14-ADA Keyboard Key Replacement, Keyboard Key: 1 단계, 이미지 1개 중 1개
      • Place the flat edge of a spudger under the key, and push slightly to pop it off.
      댓글 쓰기
    2. Lenovo V14-ADA Keyboard Key Replacement: 2 단계, 이미지 1개 중 1개
      • Clean the area by using a compressed air bottle to remove any dust or debris.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
7다른 기여자 명과 함께
Samaya Roukoz
회원 가입일: 03/19/24
268 평판
안내서 3개를 작성함
UMass Dartmouth, Team 4-2, Shaddix Spring 2024 UMass Dartmouth, Team 4-2, Shaddix Spring 2024 회원
UMASSD-SHADDIX-S24S4G2
5 회원들
안내서 15개를 작성함
1가이드 댓글
One thing this guide doesn't mention: there are three different scissor retainer clip styles across Lenovo models, and they're not interchangeable. The V14-ADA uses a dual-post style — if you order a butterfly clip by mistake it won't seat correctly. You can identify which you have by looking at the tab shapes in the empty socket (rectangular tabs = dual-post, angled/curved tabs = butterfly). Worth confirming before ordering. I got my replacement parts from laptop-keys.com by searching the model number — they have a clip-type filter that helped me avoid getting the wrong one.
Jeff Horton - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 12
지난 30일: 49
전체 시간: 1,021
