소개
Use this guide to replace the battery in your Lenovo Yoga 6 13ALC6 Laptop.
For your safety, discharge the battery below 25% before disassembling your device. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
필요한 것
Use a T5 Torx screwdriver to remove the six 7.2 mm screws securing the lower case.
Insert an opening pick between the lower case and the chassis at a hinge corner.
Pry up with the pick to release the clips securing the lower case.
Repeat the process on the other hinge corner.
Slide the pick along the right edge to release the clips securing the lower case.
Continue sliding the opening pick along the front and left edges to release the remaining clips.
Use the pointed end of a spudger to push each side of the battery connector until it comes out of the socket.
Use a Phillips screwdriver to remove the five 4.2 mm-long screws securing the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
다른 2명이 해당 안내서를 완성하였습니다.
