주요 콘텐츠로 건너뛰기
Lenovo Yoga 900-13ISK Battery Replacement
필요한 것
  1. Lenovo Yoga 900-13ISK Battery Replacement, Back Cover: 1 단계, 이미지 1/2 Lenovo Yoga 900-13ISK Battery Replacement, Back Cover: 1 단계, 이미지 2/2
    • Using a T5 Torx screwdriver, remove the ten 5.5 mm screws from the back case of the laptop.
  2. Lenovo Yoga 900-13ISK Battery Replacement: 2 단계, 이미지 1/3 Lenovo Yoga 900-13ISK Battery Replacement: 2 단계, 이미지 2/3 Lenovo Yoga 900-13ISK Battery Replacement: 2 단계, 이미지 3/3
    • Use a spudger to pry open the back case at the hinges of the laptop.
    • There are plastic clips around the perimeter of the case holding down the back cover. These will need to be popped off as the cover is removed.
    • Use your fingers to completely pop off the back cover.
  3. Lenovo Yoga 900-13ISK Battery Replacement, Battery: 3 단계, 이미지 1/3 Lenovo Yoga 900-13ISK Battery Replacement, Battery: 3 단계, 이미지 2/3 Lenovo Yoga 900-13ISK Battery Replacement, Battery: 3 단계, 이미지 3/3
    • Remove the five 3.6 mm screws from the battery with a Phillips #00 screwdriver.
  4. Lenovo Yoga 900-13ISK Battery Replacement: 4 단계, 이미지 1/3 Lenovo Yoga 900-13ISK Battery Replacement: 4 단계, 이미지 2/3 Lenovo Yoga 900-13ISK Battery Replacement: 4 단계, 이미지 3/3
    • Grab the bottom corners of the battery and gently pull the battery until the cable disconnects from the connector on the motherboard.
    • While reassembling, use a plastic spudger to push the battery cable into the connector on the underside of the motherboard. This will be easier to do before the screws are replaced.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 한 분이 해당 안내서를 완성하였습니다.
Austin Blakely
회원 가입일: 03/11/19
19,855 평판
안내서 53개 작성하였습니다
iFixit iFixit 회원
Staff
141 회원들
안내서 17,895개 작성하였습니다
댓글 한 개
Phillips 00 will not fit the 5 screws in my computer!
Elaine Gelb - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 48
전체 시간: 2,810
