주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo Yoga Tablet 10 Wi-Fi Module Replacement
필요한 것
    1. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Remove the two Phillips #000 screws.
      • These screws are located behind the stand for the device.
      • Our device did not include these screws.
      댓글 쓰기
    2. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 2 단계, 이미지 1개 중 1개
      • Use a plastic iFixit opening tool to pry the edges of the back case loose by placing it in between the edge of the cover and the screen.
      • Do not immediately attempt to remove the back of the case without attempting Step three, or you risk snapping the back cover.
      댓글 쓰기
    3. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 3 단계, 이미지 2개 중 1개 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 3 단계, 이미지 2개 중 2개
      • Use the spudger to reach into the center of the device and pry off the back case by giving it a light force upwards.
      댓글 쓰기
    1. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement, Back Camera: 4 단계, 이미지 2개 중 1개 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement, Back Camera: 4 단계, 이미지 2개 중 2개
      • Remove one 5mm screw using the Phillips #00 Screwdriver.
      댓글 쓰기
    2. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 5 단계, 이미지 3개 중 1개 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 5 단계, 이미지 3개 중 2개 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 5 단계, 이미지 3개 중 3개
      • Use the spudger to disconnect the camera and battery from the printed circuit board by putting the spudger in between the connections and the printed circuit board and pushing the spudger up.
      댓글 쓰기
    3. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 6 단계, 이미지 1개 중 1개
      • Remove one 5mm screw with the Phillips #00 screwdriver.
      댓글 쓰기
    4. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 7 단계, 이미지 3개 중 1개 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 7 단계, 이미지 3개 중 2개 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 7 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • Use the nylon tip tweezers to push the camera out from between the power button and the kickstand.
      댓글 쓰기
    1. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement, Camera PCB: 8 단계, 이미지 1개 중 1개
      • Remove the four 1 mm screws with a Phillips #00 Screwdriver.
      댓글 쓰기
    2. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 9 단계, 이미지 2개 중 1개 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 9 단계, 이미지 2개 중 2개
      • Use a spudger to disconnect the ribbon wire by applying a force upwards.
      댓글 쓰기
    3. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 10 단계, 이미지 2개 중 1개 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 10 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use tweezers to lift up the foil.
      • The foil may tear.
      댓글 쓰기
    4. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 11 단계, 이미지 2개 중 1개 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 11 단계, 이미지 2개 중 2개
      • Use the tweezers to lift the black tape from the corner of the printed circuit board.
      댓글 쓰기
    5. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 12 단계, 이미지 3개 중 1개 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 12 단계, 이미지 3개 중 2개 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 12 단계, 이미지 3개 중 3개
      • Flip the board 180 degrees towards you using the tweezers.
      댓글 쓰기
    1. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement, Wi-Fi Module: 13 단계, 이미지 2개 중 1개 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement, Wi-Fi Module: 13 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Remove the wire from the PCB by pulling it towards the edge of the headphone jack using tweezers.
      댓글 쓰기
    2. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 14 단계, 이미지 3개 중 1개 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 14 단계, 이미지 3개 중 2개 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 14 단계, 이미지 3개 중 3개
      • Remove the one 5mm screw using a Phillips #00 Screwdriver.
      댓글 쓰기
    3. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 15 단계, 이미지 3개 중 1개 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 15 단계, 이미지 3개 중 2개 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 15 단계, 이미지 3개 중 3개
      • Using tweezers remove the tape to disconnect the module by pulling it upward.
      댓글 쓰기
    4. Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 16 단계, 이미지 2개 중 1개 Lenovo Yoga Tablet 10 Wi-Fi Module Replacement: 16 단계, 이미지 2개 중 2개
      • Remove the yellow piece of tape by pulling it upward using tweezers.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Rachel Potratz
회원 가입일: 01/24/19
118 평판
안내서 1개를 작성함
Cal Poly, Team S2-G6, White Winter 2019 Cal Poly, Team S2-G6, White Winter 2019 회원
CPSU-WHITE-W19S2G6
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 27
전체 시간: 671
