주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lens Replacement
필요한 것
  1. Lens Replacement, Removing the Battery: 1 단계, 이미지 3개 중 1개 Lens Replacement, Removing the Battery: 1 단계, 이미지 3개 중 2개 Lens Replacement, Removing the Battery: 1 단계, 이미지 3개 중 3개
    • Flip the small blue switch up to release the battery. Remove the battery.
    • Remove two Philips #000 screws. Place the screws on a magnetic pad or somewhere safe.
    • Insert a plastic opening tool in the corner by the Micro USB plug. This area will allow leverage in order to take off the outer case.
    댓글 쓰기
  2. Lens Replacement, Removing the Outer Casing: 2 단계, 이미지 3개 중 1개 Lens Replacement, Removing the Outer Casing: 2 단계, 이미지 3개 중 2개 Lens Replacement, Removing the Outer Casing: 2 단계, 이미지 3개 중 3개
    • Use the opening tool and your fingers to pry apart the outer case. Hold back camera as well as menu navigation buttons while you remove the case.
    • Unscrew two small Phillips screws holding the outer case to the motherboard. Use the opening tool to unhook the case from the plate covering the motherboard.
    • The second screw (top left) is under the control PCB. The PCB is mounted to a metal plate that is retained by some adhesive tape underneath and two prongs (bottom-left). You need to pry the plate from the top-right until the tape is broken, then slide the plate upwards (relative to photo). Take care not to pull or tear the ribbon cable.
    댓글 쓰기
  3. Lens Replacement, Removing the Ribbon: 3 단계, 이미지 2개 중 1개 Lens Replacement, Removing the Ribbon: 3 단계, 이미지 2개 중 2개
    • Disconnect the button casing ribbon cable from the motherboard.
    • Be gentle when removing the ribbon.
    • Lift up the metal casing with one hand and use the other hand to snap the ZIF connector back, in order to remove the display ribbon cable.
    댓글 쓰기
  4. Lens Replacement, Replacing the Lens: 4 단계, 이미지 3개 중 1개 Lens Replacement, Replacing the Lens: 4 단계, 이미지 3개 중 2개 Lens Replacement, Replacing the Lens: 4 단계, 이미지 3개 중 3개
    • Remove the display and buttons.
    • Release the clamp on the two ribbon cables connected to the camera lens.
    • Be gentle when removing the ribbons cables. They are fragile and can tear.
    • Pull the lens out of the camera base.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
salome datong
회원 가입일: 09/26/16
104 평판
안내서 1개를 작성함
USF Tampa, Team 14-4, Eyestone Fall 2016 USF Tampa, Team 14-4, Eyestone Fall 2016 회원
USFT-EYESTONE-F16S14G4
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 50
전체 시간: 2,001
