주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Levoit Core 300-RAC Control Board Replacement
필요한 것
    1. Levoit Core 300-RAC Control Board Replacement, Control Board: 1 단계, 이미지 3개 중 1개 Levoit Core 300-RAC Control Board Replacement, Control Board: 1 단계, 이미지 3개 중 2개 Levoit Core 300-RAC Control Board Replacement, Control Board: 1 단계, 이미지 3개 중 3개
      • Make sure the device is turned off and unplugged before disassembling it.
      • Insert the Jimmy between the gray grille cover and the top of the device.
      • Work your way around the grille cover with the Jimmy to release the clips holding it in place.
      • Take note of the placement of the clips, as they are keyed and need to go back in the exact way they came out.
      • Remove the grille cover gently as it is connected by a ribbon cable.
      • Be careful not to put too much strain on the ribbon cable as it may break.
      댓글 쓰기
    2. Levoit Core 300-RAC Control Board Replacement: 2 단계, 이미지 3개 중 1개 Levoit Core 300-RAC Control Board Replacement: 2 단계, 이미지 3개 중 2개 Levoit Core 300-RAC Control Board Replacement: 2 단계, 이미지 3개 중 3개
      • Squeeze the tab on the connector to release the bundled cable from the control board.
      • The connector should come out fairly easily, so do not force it. Pulling too hard could damage the connector.
      댓글 쓰기
    3. Levoit Core 300-RAC Control Board Replacement: 3 단계, 이미지 2개 중 1개 Levoit Core 300-RAC Control Board Replacement: 3 단계, 이미지 2개 중 2개
      • Gently bend the gray plastic cover to release the control board.
      • There are several hard tabs holding the control board in place.
      댓글 쓰기
    4. Levoit Core 300-RAC Control Board Replacement: 4 단계, 이미지 3개 중 1개 Levoit Core 300-RAC Control Board Replacement: 4 단계, 이미지 3개 중 2개 Levoit Core 300-RAC Control Board Replacement: 4 단계, 이미지 3개 중 3개
      • Lift the control board from the gray plastic cover.
      • Take note of the orientations of the buttons, as that will help during reassembly.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Mustafa
회원 가입일: 11/03/23
259 평판
안내서 1개를 작성함
UMass Dartmouth, Team 1-6, Petersen Fall 2023 UMass Dartmouth, Team 1-6, Petersen Fall 2023 회원
UMASSD-PETERSEN-F23S1G6
5 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 22
지난 30일: 85
전체 시간: 1,863
