주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LexiBook Tablet One Camera Replacement
필요한 것
    1. LexiBook Tablet One Camera Replacement, Camera: 1 단계, 이미지 3개 중 1개 LexiBook Tablet One Camera Replacement, Camera: 1 단계, 이미지 3개 중 2개 LexiBook Tablet One Camera Replacement, Camera: 1 단계, 이미지 3개 중 3개
      • Find the seam in the casing. Insert the blue plastic opening tool, and slide to either side carefully undoing the clips. The clips are hidden within the casing and are spaced roughly 1.5 in. apart.
      • When opening the device, be wary of the speaker wire. It is best to open the device from the right side with the camera oriented to the top.
      댓글 쓰기
    2. LexiBook Tablet One Camera Replacement: 2 단계, 이미지 2개 중 1개 LexiBook Tablet One Camera Replacement: 2 단계, 이미지 2개 중 2개
      • Insert a spudger between the speaker and the casing. Gently pop the speaker out, and set the panel to the side.
      댓글 쓰기
    3. LexiBook Tablet One Camera Replacement: 3 단계, 이미지 1개 중 1개
      • Using a plastic spudger, wedge the tool between the battery and LCD. Repeatedly gouge and work around the edges of the battery until the adhesive breaks free. You will have to apply generous pressure, as long as you push horizontally the components should not be further damaged.
      • Be careful not to damage any wires or to puncture the battery casing when peeling the adhesive.
      • A similar flat tool can be used in place of a plastic spudger.
      댓글 쓰기
    4. LexiBook Tablet One Camera Replacement: 4 단계, 이미지 3개 중 1개 LexiBook Tablet One Camera Replacement: 4 단계, 이미지 3개 중 2개 LexiBook Tablet One Camera Replacement: 4 단계, 이미지 3개 중 3개
      • Remove the ribbon cable leading to the camera by carefully using a flat headed tool to open the ribbon clip.
      • Gently slide the ribbon cable out while holding the clip open.
      댓글 쓰기
    5. LexiBook Tablet One Camera Replacement: 5 단계, 이미지 1개 중 1개
      • When inserting your new camera, maintain the clip's open position and slide the new ribbon cable in.
      • It is imperative the clip not close partially when installing the new ribbon, or the new cable can be damaged.
      • When the ribbon can go no further into the clip, close the clip.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jordan
회원 가입일: 03/11/15
650 평판
안내서 4개를 작성함
Colorado Springs, Team 2-5, Panko Spring 2015 Colorado Springs, Team 2-5, Panko Spring 2015 회원
UCCS-PANKO-S15S2G5
3 회원들
안내서 30개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 28
전체 시간: 480
