주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Linksys WAP 11 Network Port Replacement
필요한 것
    1. Linksys WAP 11 Network Port Replacement, Outer Case: 1 단계, 이미지 1개 중 1개
      • Disconnect the power cables and ethernet from the device.
      • Unscrew the external plastic antennas. There is one antenna on each side of the device.
      댓글 쓰기
    2. Linksys WAP 11 Network Port Replacement: 2 단계, 이미지 3개 중 1개 Linksys WAP 11 Network Port Replacement: 2 단계, 이미지 3개 중 2개 Linksys WAP 11 Network Port Replacement: 2 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • To open the Linksys WAP11, you will need a Phillips #1 screwdriver and a pair of metal tweezers.
      • Use the tweezers to remove the two rubber boots from the front two legs. Insert the tweezers in the hole of the boot and pull outwards.
      • This will reveal two small Phillips-head screws. Remove them.
      • Keep these two screws together.
      댓글 쓰기
    3. Linksys WAP 11 Network Port Replacement: 3 단계, 이미지 2개 중 1개 Linksys WAP 11 Network Port Replacement: 3 단계, 이미지 2개 중 2개
      • Using two hands, pull on the top and bottom sections to separate the blue and the black pieces.
      • This requires significant amount of force.
      • The seal is located where the blue plastic meets the black plastic. This is where you will apply pressure.
      댓글 쓰기
    4. Linksys WAP 11 Network Port Replacement: 4 단계, 이미지 1개 중 1개
      • After the face of the device has been removed, slide the base of the device off to reveal the motherboard and other internal components.
      • When removing the base, do not damage the wires that are attached to the device.
      댓글 쓰기
    5. Linksys WAP 11 Network Port Replacement: 5 단계, 이미지 1개 중 1개
      • This is what the device looks like when it is fully opened.
      댓글 쓰기
    1. Linksys WAP 11 Network Port Replacement, Motherboard: 6 단계, 이미지 2개 중 1개 Linksys WAP 11 Network Port Replacement, Motherboard: 6 단계, 이미지 2개 중 2개
      • At this point, remove the antenna leads as well.
      • Proceed to remove the remaining three phillips screws fastening the motherboard to the case.
      • Once the screws are removed, your motherboard will separate from the housing.
      • Keep these three screws together and separate from the outer case screws.
      댓글 쓰기
    1. Linksys WAP 11 Network Port Replacement, Network Port: 7 단계, 이미지 1개 중 1개
      • Ifixit soldering guide Soldering and desoldering have the potential for harm, always wear proper eye protection and other personal protective equipment while performing either action!
      • Turn the main circuit board around and using a soldering iron and desoldering wick desolder the 12 pins that secure the port to the main board.
      댓글 쓰기
    2. Linksys WAP 11 Network Port Replacement: 8 단계, 이미지 2개 중 1개 Linksys WAP 11 Network Port Replacement: 8 단계, 이미지 2개 중 2개
      • Using a pair of needle-nose pliers, squeeze the two black plastic clips that secure the network port to the board. Squeeze and push down at the same time to push the network board out of place and remove it from the board.
      • To replace the network port, line up the black plastic clips and pop a new network port into the holes. Reassemble in reverse order.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
8다른 기여자 명과 함께
Joe M
회원 가입일: 10/12/11
159 평판
안내서 3개를 작성함
Cal Poly, Team 3-17, Regan Fall 2011 Cal Poly, Team 3-17, Regan Fall 2011 회원
CPSU-REGAN-F11S3G17
5 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 9
지난 30일: 33
전체 시간: 1,218
