주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LisaTerminal with Linux/UNIX(Mac)
필요한 것
  1. LisaTerminal with Linux/UNIX(Mac), On Linux: 1 단계, 이미지 1개 중 1개
    • In Terminal type: sudo apt-get install screen
    • sudo screen /dev/ttyUSB0 9600
    • Press ⌃A ⇧ : (at the same time). Once you see a : prompt at the bottom of the screen type
    • exec ::: /sbin/agetty -L -n 9600 ttyUSB0 vt100
    • Press return a few times on the Lisa keyboard and the login prompt should appear.
    댓글 쓰기
  2. LisaTerminal with Linux/UNIX(Mac), On macOS: 2 단계, 이미지 1개 중 1개
    • Type: ls /dev/cu.*
    • Copy the result that mentions USB
    • Then type the following replacing serial with the previous result: screen /dev/serial 9600
    • Press ⌃A ⇧:
    • When the : prompt appears type
    • exec ::: /usr/libexec/getty std.9600
    댓글 쓰기
    • Open LisaTerminal and set the settings to baud rate 9600 and set serial port to A.
    • Plug the serial cable into serial port A.
    • In MacWorks Plus and Macintosh System 6, the application Mac240 supports graphics and is generally fantastic for this type of connection.
    • Mac240 can be acquired from Macintosh Garden.
    댓글 쓰기
  3. LisaTerminal with Linux/UNIX(Mac), Uses: 4 단계, 이미지 1개 중 1개
    • This was done so I could use mutt for email and w3m for web browsing
    • mpg123 is great for music if your connected computer has speakers.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
LisaGuide
회원 가입일: 12/30/18
1,833 평판
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 36
전체 시간: 1,010
