주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech Folio Touch Key Repair/Replacement
필요한 것
    1. Logitech Folio Touch Key Repair/Replacement, Make sure you have all of the pieces: 1 단계, 이미지 1개 중 1개
      • Make sure you have all 3 peices of the key to be able to put it back together.
      • You should have: the key cap and the two plastic pieces
      댓글 쓰기
    2. Logitech Folio Touch Key Repair/Replacement, Clip the circle piece onto the keycap: 2 단계, 이미지 1개 중 1개
      • Clip the plastic piece with the circular cutout into the keycap.
      댓글 쓰기
    3. Logitech Folio Touch Key Repair/Replacement, Hook and lay the square piece in the key slot: 3 단계, 이미지 2개 중 1개 Logitech Folio Touch Key Repair/Replacement, Hook and lay the square piece in the key slot: 3 단계, 이미지 2개 중 2개
      • Lay the square plastic piece in the key slot and hook the holes in place. Make sure the divot on the square piece is facing down.
      댓글 쓰기
    4. Logitech Folio Touch Key Repair/Replacement, Slide the circle piece through the square piece: 4 단계, 이미지 3개 중 1개 Logitech Folio Touch Key Repair/Replacement, Slide the circle piece through the square piece: 4 단계, 이미지 3개 중 2개 Logitech Folio Touch Key Repair/Replacement, Slide the circle piece through the square piece: 4 단계, 이미지 3개 중 3개
      • Slide the circle piece attached to the key cap through the square piece and try to slide it onto the hook.
      • This part may be tricky, you may need to use tweezers to lift up the square piece so you don't unhook it.
      댓글 쓰기
    5. Logitech Folio Touch Key Repair/Replacement, Push key into place: 5 단계, 이미지 2개 중 1개 Logitech Folio Touch Key Repair/Replacement, Push key into place: 5 단계, 이미지 2개 중 2개
      • Finally, push down lightly on the key. Once you hear it snap into place, you should be done. Lightly shake the keyboard up and down to make sure it is securely in place.
      • If you do not hear it snap into place, and you feel resistance from it, make sure the plastic pieces are oriented the correct way.
      • If there is a snap but the key hangs upside down the plastic hooks on the keycap may be worn down. You can try to use tape to hold it in place then remove it once the keycap is in place.
      댓글 쓰기
결론
If something is still not working consider reaching out to Logitech support for additional support.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Andrew Washburn
회원 가입일: 02/04/26
121 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 69
전체 시간: 220
