주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech G Cloud Right Joystick Replacement
필요한 것
  1. Logitech G Cloud Right Joystick Replacement, Case: 1 단계, 이미지 2개 중 1개 Logitech G Cloud Right Joystick Replacement, Case: 1 단계, 이미지 2개 중 2개
    • Power the device off and turn it over so the screen is face down.
    • Insert an opening pick into the seam between the back plate and left handguard.
    • Pry around the entire perimeter until the handguard fully releases.
    • Remove the handguard.
    • Repeat the previous three bullets on the right handguard.
    댓글 쓰기
  2. Logitech G Cloud Right Joystick Replacement: 2 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove all eight 10 mm screws from the rear case located under where the handguards were.
    댓글 쓰기
  3. Logitech G Cloud Right Joystick Replacement: 3 단계, 이미지 2개 중 1개 Logitech G Cloud Right Joystick Replacement: 3 단계, 이미지 2개 중 2개
    • Insert an opening pick into the seam between the midframe and rear case.
    • Gently pry the rear case upwards to separate it from the midframe.
    댓글 쓰기
  4. Logitech G Cloud Right Joystick Replacement: 4 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove all seven 10 mm screws that secure the midframe.
    댓글 쓰기
  5. Logitech G Cloud Right Joystick Replacement: 5 단계, 이미지 2개 중 1개 Logitech G Cloud Right Joystick Replacement: 5 단계, 이미지 2개 중 2개
    • Insert an opening pick into the seam between the midframe and front case at the top of the device to separate the interior plating.
    • Gently pry out the midframe by lifting an opening pick.
    • You may hear loud popping noises when you remove the interior plating. That's the sound of the retaining clips disengaging.
    댓글 쓰기
  6. Logitech G Cloud Right Joystick Replacement, Right Joystick: 6 단계, 이미지 3개 중 1개 Logitech G Cloud Right Joystick Replacement, Right Joystick: 6 단계, 이미지 3개 중 2개 Logitech G Cloud Right Joystick Replacement, Right Joystick: 6 단계, 이미지 3개 중 3개
    • Use a spudger to lift upwards and disconnect the metallic sticker from the console.
    • The sticker should stay attached to the joystick plate.
    • Insert the flat end of a spudger under the joystick press connector and lift upwards to disconnect it.
    • Use a spudger to remove the R2 trigger sensor from the joystick plate; it should stay attached to the console.
    댓글 쓰기
  7. Logitech G Cloud Right Joystick Replacement: 7 단계, 이미지 2개 중 1개 Logitech G Cloud Right Joystick Replacement: 7 단계, 이미지 2개 중 2개
    • Use a Phillips #00 screwdriver to remove all three 10 mm screws that secure the joystick assembly.
    • Pop the joystick out with your fingers.
    댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Spencer Davis
회원 가입일: 01/23/25
535 평판
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 18
지난 30일: 72
전체 시간: 620
