주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech G Pro Wireless Mouse Side Button Switch Replacement
필요한 것
    1. Logitech G Pro Wireless Mouse Side Button Switch Replacement, Side Button Switch: 1 단계, 이미지 1개 중 1개
      • OPTIONAL BUT RECOMMENDED STEPS:
      • Find a stable desk or table to work on.
      • Create a clean work area on the surface.
      • Set up a mat on the work area.
      • Place the mouse on the work area.
      댓글 쓰기
    2. Logitech G Pro Wireless Mouse Side Button Switch Replacement: 2 단계, 이미지 1개 중 1개
      • Flip the power switch to OFF.
      • The power switch is located on the bottom of the mouse.
      댓글 쓰기
    3. Logitech G Pro Wireless Mouse Side Button Switch Replacement: 3 단계, 이미지 2개 중 1개 Logitech G Pro Wireless Mouse Side Button Switch Replacement: 3 단계, 이미지 2개 중 2개
      • Optional: Gently apply heat to the bottom of mouse using heat gun for easier removal of skates. If you intend to reuse the skates, take care not to strain, warp, or tear them.
      • Use a spudger to gently lift and remove the five skates.
      댓글 쓰기
    4. Logitech G Pro Wireless Mouse Side Button Switch Replacement: 4 단계, 이미지 3개 중 1개 Logitech G Pro Wireless Mouse Side Button Switch Replacement: 4 단계, 이미지 3개 중 2개 Logitech G Pro Wireless Mouse Side Button Switch Replacement: 4 단계, 이미지 3개 중 3개
      • Remove the seven 4.4 mm-long Phillips #00 screws on the bottom shell of the mouse.
      • The screws are located underneath the edge skates.
      • Place the screws into a container to avoid losing them. Organize the screws into separate containers based on the step they were removed on to avoid incorrect reassembly.
      댓글 쓰기
    5. Logitech G Pro Wireless Mouse Side Button Switch Replacement: 5 단계, 이미지 2개 중 1개 Logitech G Pro Wireless Mouse Side Button Switch Replacement: 5 단계, 이미지 2개 중 2개
      • Separate the bottom shell of the mouse from the top shell.
      • Remove the single 3 mm-long Phillips #00 screw securing the battery bracket.
      • Pop the battery out gently with the spudger.
      • Be careful not to damage the battery as it can leak toxic chemicals, catch fire, or explode.
      댓글 쓰기
    6. Logitech G Pro Wireless Mouse Side Button Switch Replacement: 6 단계, 이미지 3개 중 1개 Logitech G Pro Wireless Mouse Side Button Switch Replacement: 6 단계, 이미지 3개 중 2개 Logitech G Pro Wireless Mouse Side Button Switch Replacement: 6 단계, 이미지 3개 중 3개
      • Use the tweezers to lift up the electrical ribbon locking tab.
      • Gently pull out the ribbon to separate the bottom shell and top shell of the mouse.
      • If the ribbon does not release, gently wiggle the ribbon while carefully pulling to remove. Do not forcefully pull the ribbon as it can get damaged.
      댓글 쓰기
    7. Logitech G Pro Wireless Mouse Side Button Switch Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the four 3 mm-long Phillips #00 screws securing the left and right mouse buttons on the inside of the top shell.
      댓글 쓰기
    8. Logitech G Pro Wireless Mouse Side Button Switch Replacement: 8 단계, 이미지 3개 중 1개 Logitech G Pro Wireless Mouse Side Button Switch Replacement: 8 단계, 이미지 3개 중 2개 Logitech G Pro Wireless Mouse Side Button Switch Replacement: 8 단계, 이미지 3개 중 3개
      • Flip the top shell over.
      • Remove the right and left mouse buttons.
      댓글 쓰기
    9. Logitech G Pro Wireless Mouse Side Button Switch Replacement: 9 단계, 이미지 3개 중 1개 Logitech G Pro Wireless Mouse Side Button Switch Replacement: 9 단계, 이미지 3개 중 2개 Logitech G Pro Wireless Mouse Side Button Switch Replacement: 9 단계, 이미지 3개 중 3개
      • Using the screwdriver, remove the two 3 mm-long Phillips #00 screws securing the middle housing assembly inside the mouse. Set the screws aside in a safe place to avoid losing them.
      • Using the spudger, gently pry up the middle housing assembly from the edges. Carefully lift the middle section out of the mouse body.
      댓글 쓰기
    10. Logitech G Pro Wireless Mouse Side Button Switch Replacement: 10 단계, 이미지 3개 중 1개 Logitech G Pro Wireless Mouse Side Button Switch Replacement: 10 단계, 이미지 3개 중 2개 Logitech G Pro Wireless Mouse Side Button Switch Replacement: 10 단계, 이미지 3개 중 3개
      • Using the screwdriver, remove the four 3 mm-long Phillips #00 screws securing the scroll wheel assembly to the mouse.
      • Using the spudger, gently lift the small ribbon cable connector from the circuit board. Carefully disconnect the ribbon cable by pulling it straight out of the connector.
      • Do not pull on the ribbon cable itself. Always lift from the connector to avoid tearing the cable.
      • Once disconnected, lift and remove the scroll wheel assembly from the mouse.
      댓글 쓰기
    11. Logitech G Pro Wireless Mouse Side Button Switch Replacement: 11 단계, 이미지 3개 중 1개 Logitech G Pro Wireless Mouse Side Button Switch Replacement: 11 단계, 이미지 3개 중 2개 Logitech G Pro Wireless Mouse Side Button Switch Replacement: 11 단계, 이미지 3개 중 3개
      • Using the screwdriver, remove the four 3mm Phillips #00 screws securing the blue side button brackets on both sides of the mouse.
      • Remove the nine 3 mm-long Phillips #00 screws securing the main internal frame (black plastic structure).
      • Remove the single 3mm Phillips #00 screw at the top of the mouse near the front end.
      • Set all screws aside in an organized manner to avoid mixing them up.
      댓글 쓰기
    12. Logitech G Pro Wireless Mouse Side Button Switch Replacement: 12 단계, 이미지 3개 중 1개 Logitech G Pro Wireless Mouse Side Button Switch Replacement: 12 단계, 이미지 3개 중 2개 Logitech G Pro Wireless Mouse Side Button Switch Replacement: 12 단계, 이미지 3개 중 3개
      • Carefully lift the internal assembly out of the outer mouse shell. Set the outer shell aside.
      • Remove the blue side button brackets from both sides of the internal frame.
      • Gently lift out the four side buttons from the frame.
      댓글 쓰기
    13. Logitech G Pro Wireless Mouse Side Button Switch Replacement: 13 단계, 이미지 3개 중 1개 Logitech G Pro Wireless Mouse Side Button Switch Replacement: 13 단계, 이미지 3개 중 2개 Logitech G Pro Wireless Mouse Side Button Switch Replacement: 13 단계, 이미지 3개 중 3개
      • Using the spudger, gently pry up the edge of the side circuit board from the plastic frame. Work your way along the edge, carefully releasing the clips holding the board in place.
      • Once loosened, lift the side circuit board away from the frame.
      댓글 쓰기
    14. Logitech G Pro Wireless Mouse Side Button Switch Replacement: 14 단계, 이미지 3개 중 1개 Logitech G Pro Wireless Mouse Side Button Switch Replacement: 14 단계, 이미지 3개 중 2개 Logitech G Pro Wireless Mouse Side Button Switch Replacement: 14 단계, 이미지 3개 중 3개
      • Using the spudger, gently insert the tip under the edge of the circuit board. Carefully pry upward to separate the board from the adhesive securing it to the frame.
      • Continue working along the edges until the adhesive is fully released. Once loosened, lift the circuit board assembly away from the frame.
      • If the adhesive is strong, apply slow, steady pressure instead of forcing it up quickly.
      댓글 쓰기
    15. Logitech G Pro Wireless Mouse Side Button Switch Replacement: 15 단계, 이미지 3개 중 1개 Logitech G Pro Wireless Mouse Side Button Switch Replacement: 15 단계, 이미지 3개 중 2개 Logitech G Pro Wireless Mouse Side Button Switch Replacement: 15 단계, 이미지 3개 중 3개
      • Desolder the switch pins on the underside of the PCB.
      • Using the spudger, gently insert the tip underneath the side switch component. Carefully lift the edge of the switch to begin separating it from the board.
      • Use a second tool (such as tweezers or a flathead tool) to assist in prying the switch upward. Continue applying gentle pressure until the side switch is fully detached from the board.
      • Avoid applying excessive force, as this may damage the circuit board or surrounding components.
      • This is the final disassembly step. Begin reassembly starting here after replacing the button switch.
      댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Shane Guzman
회원 가입일: 02/26/26
241 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 18
지난 7일: 77
지난 30일: 316
전체 시간: 586
