주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech G305 Mouse Left Clicker Replacement
필요한 것
  1. Logitech G305 Mouse Left Clicker Replacement, Left Clicker: 1 단계, 이미지 2개 중 1개 Logitech G305 Mouse Left Clicker Replacement, Left Clicker: 1 단계, 이미지 2개 중 2개
    • Remove the battery cover by pressing the top of the cover and pulling it downwards.
    • Remove the battery.
    댓글 쓰기
  2. Logitech G305 Mouse Left Clicker Replacement: 2 단계, 이미지 3개 중 1개 Logitech G305 Mouse Left Clicker Replacement: 2 단계, 이미지 3개 중 2개 Logitech G305 Mouse Left Clicker Replacement: 2 단계, 이미지 3개 중 3개
    • Carefully use a box cutter to follow the grooves of the mouse skate pads and slowly lift them off.
    • Use a Phillips #00 screwdriver to remove the four screws.
    댓글 쓰기
  3. Logitech G305 Mouse Left Clicker Replacement: 3 단계, 이미지 2개 중 1개 Logitech G305 Mouse Left Clicker Replacement: 3 단계, 이미지 2개 중 2개
    • Use a spudger to carefully separate the two halves of the mouse near the battery compartment.
    댓글 쓰기
  4. Logitech G305 Mouse Left Clicker Replacement: 4 단계, 이미지 2개 중 1개 Logitech G305 Mouse Left Clicker Replacement: 4 단계, 이미지 2개 중 2개
    • Open the compartment and slowly separate the halves until the internal wires are exposed.
    • Carefully disconnect the two wires by hand from the base.
    • The wires are fragile and require careful handling.
    댓글 쓰기
  5. Logitech G305 Mouse Left Clicker Replacement: 5 단계, 이미지 3개 중 1개 Logitech G305 Mouse Left Clicker Replacement: 5 단계, 이미지 3개 중 2개 Logitech G305 Mouse Left Clicker Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the three screws from the center battery compartment using a Phillips #00 screwdriver.
    • Remove the two screws securing the left clicker.
    댓글 쓰기
  6. Logitech G305 Mouse Left Clicker Replacement: 6 단계, 이미지 2개 중 1개 Logitech G305 Mouse Left Clicker Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the battery compartment to gain easy access to the clicker.
    • Lift the battery compartment with care because of fragile wires.
    • Remove the left clicker.
    댓글 쓰기
  7. Logitech G305 Mouse Left Clicker Replacement: 7 단계, 이미지 2개 중 1개 Logitech G305 Mouse Left Clicker Replacement: 7 단계, 이미지 2개 중 2개
    • Insert the replacement component and slide it into position until it securely clicks into place.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Juan Iniguez
회원 가입일: 09/30/25
172 평판
안내서 1개를 작성함
CSU Los Angeles, Team 8-9, Grodsky Fall 2025 CSU Los Angeles, Team 8-9, Grodsky Fall 2025 회원
CSULA-GRODSKY-F25S8G9
2 회원들
안내서 1개 작성
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 65
지난 30일: 361
전체 시간: 2,294
