주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech G305 Scroll Wheel Replacement
필요한 것
  1. Logitech G305 Scroll Wheel Replacement, Scroll Wheel: 1 단계, 이미지 2개 중 1개 Logitech G305 Scroll Wheel Replacement, Scroll Wheel: 1 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Flathead 1.5 mm Screwdriver
    $1.99
    • Use a 1.5 mm flathead screwdriver to remove the four mouse skates from the bottom of the mouse.
    댓글 쓰기
  2. Logitech G305 Scroll Wheel Replacement: 2 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the four bottom case screws.
    • Caution, do not strip the head of the screws. These are not easily replaceable.
    댓글 쓰기
  3. Logitech G305 Scroll Wheel Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the palm cover by simply sliding downwards. Remove the battery and the bluetooth usb.
    • Using a flat head screwdriver 1.5mm to not pry but to adjust the connector. By doing this it will allow you to open the inside.
    • Use caution when raising the outer shell—wires are still connected inside.
    댓글 쓰기
  4. Logitech G305 Scroll Wheel Replacement: 4 단계, 이미지 2개 중 1개 Logitech G305 Scroll Wheel Replacement: 4 단계, 이미지 2개 중 2개
    • Using the flathead screwdriver 1.5mm you can undo the clip holding the wiring in place.
    댓글 쓰기
  5. Logitech G305 Scroll Wheel Replacement: 5 단계, 이미지 1개 중 1개
    • There is a metal spring that holds one side of the scroll wheel, remove the metal spring using a flathead screwdriver 1.5mm and lifting the scroll wheel.
    댓글 쓰기
  6. Logitech G305 Scroll Wheel Replacement: 6 단계, 이미지 1개 중 1개
    • Use a Phillips screw driver #00 to remove the four screws.
    • Be careful to not strip the screws, these can't be found at your local hardware store.
    댓글 쓰기
  7. Logitech G305 Scroll Wheel Replacement: 7 단계, 이미지 3개 중 1개 Logitech G305 Scroll Wheel Replacement: 7 단계, 이미지 3개 중 2개 Logitech G305 Scroll Wheel Replacement: 7 단계, 이미지 3개 중 3개
    • Using the Flathead screwdriver 1.5mm, disconnect the clip for the green and blue wire.
    • Remove the motherboard out of the casing.
    • The mouse wheel can only come out one way. Slide to the right to release mouse wheel.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Nathan Rosales
회원 가입일: 02/21/22
385 평판
안내서 1개를 작성함
1가이드 댓글
Should you encounter issues with a malfunctioning scroll wheel, consider cleaning it using a can of compressed air and then applying a small amount of PTFE-based multi-use synthetic oil to the scroll wheel housing.
tomzo88 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 115
지난 30일: 538
전체 시간: 29,521
