주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech G533 Headphones doesnt work without USB cable
필요한 것
      • If the power button lits up only if the USB cable is plugged in. You probably have a loosened power cable inside the left earcup.
      댓글 쓰기
      • If your headphones still have a warranty, just return them to the shop.
      댓글 쓰기
      • Before you start disassembling try all the guides on the official website to make sure your problem is not software-based.
      댓글 쓰기
    1. Logitech G533 Headphones  doesnt work without USB cable: 4 단계, 이미지 1개 중 1개
      • Take out the left earcup padding. Turn the right side of the earcup counterclockwise and unplug the battery.
      댓글 쓰기
    2. Logitech G533 Headphones  doesnt work without USB cable: 5 단계, 이미지 1개 중 1개
      • Unscrew 4 screws with Torx Security TR8 bit.
      댓글 쓰기
    3. Logitech G533 Headphones  doesnt work without USB cable: 6 단계, 이미지 1개 중 1개
      • Carefully move aside the speaker. There are very thin wires connected to it and the printed circuit.
      • Unscrew the 5 screws marked on the picture with Philips 0 bit.
      댓글 쓰기
    4. Logitech G533 Headphones  doesnt work without USB cable: 7 단계, 이미지 1개 중 1개
      • Loosen the screw on the picture and slide up the black top under it.
      댓글 쓰기
    5. Logitech G533 Headphones  doesnt work without USB cable: 8 단계, 이미지 1개 중 1개
      • Take out the middle frame piece.
      • You will need to push the speaker through the frame and take out the mic off the frame.
      댓글 쓰기
    6. Logitech G533 Headphones  doesnt work without USB cable: 9 단계, 이미지 1개 중 1개
      • Here you can see that the red power cable is loosened.
      댓글 쓰기
    7. Logitech G533 Headphones  doesnt work without USB cable: 10 단계, 이미지 1개 중 1개
      • It looks like the cables are not soldered to the printed circuit. Just glued to it.
      • Scrap off the glue. I used a scalpel.
      댓글 쓰기
    8. Logitech G533 Headphones  doesnt work without USB cable: 11 단계, 이미지 1개 중 1개
      • You can plug back the battery and hold the cable in its original place.
      • Switch the power button and the power light should turn on.
      • The light will turn on after 2 seconds. You will need to keep the cable in place the whole time.
      댓글 쓰기
    9. Logitech G533 Headphones  doesnt work without USB cable: 12 단계, 이미지 1개 중 1개
      • Now you have two options. You can glue the cable back in and risk it will get loosen again. Or solder it.
      • The weld on the picture was so crappy that the cable get off when I was assembling it back. And have to redo it.
      댓글 쓰기
    10. Logitech G533 Headphones  doesnt work without USB cable: 13 단계, 이미지 1개 중 1개
      • When I was assembling the headphones I noticed that the mic cable get partially naked. It happened because every time you move the mic leg the cable has contact with the insides of the earcup.
      • I recommend putting electrical tape over it or don't move the mic leg at all. Just use the mute button on the back of the left earcup.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kobda
회원 가입일: 01/14/21
437 평판
안내서 1개를 작성함
9가이드 댓글
Hi, its possible to disassembly the mic to change the cable? Mine its cut in the middle and I need to replace
Sauron666 - 답글 공유
Can you please link a picture of the problem? It will be easier for me to assess the problem.
Kobda - 답글 공유
I have just taken apart the headphone because I have a similar problem, but I could not access the cable inside the microphone 'arm' without doing something that I thought might break it... Judging from the build quality inside I also think that it would be a pain in the a** to replace and fix it.
Miguel - 답글 공유
yep, my mic cable also broke, didnt even try to fix it and rather bought external mic.
Kobda - 답글 공유
Amazing guide, I was able to fix my headset to work with batteries again. Can't believe Logitech decided to glue the cables...
Daniel Barelli - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 17
지난 30일: 66
전체 시간: 8,050
