주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech G602 Scroll Wheel Replacement
필요한 것
    1. Logitech G602 Scroll Wheel Replacement, Scroll Wheel Spring: 1 단계, 이미지 1개 중 1개
      • Use a blue spudger to pry off all 4 mouse feet from under of mouse.
      댓글 쓰기
    2. Logitech G602 Scroll Wheel Replacement: 2 단계, 이미지 1개 중 1개
      • Use a Phillips #00 screwdriver to unscrew all 6 screws (3x5mm ) from under the mouse feet.
      댓글 쓰기
    3. Logitech G602 Scroll Wheel Replacement: 3 단계, 이미지 2개 중 1개 Logitech G602 Scroll Wheel Replacement: 3 단계, 이미지 2개 중 2개
      • Lift the top of the mouse from the base of the mouse (separate the mouse in half) to expose the internal hardware.
      댓글 쓰기
    4. Logitech G602 Scroll Wheel Replacement: 4 단계, 이미지 1개 중 1개
      • Use the black spudger to move the tip of the metal spring off of the wheel.
      • The scroll wheel will not actually be removed — instead, the adjustment to the metal spring will test the wheel's usability.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 9명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jerico Morales
회원 가입일: 01/17/18
1,303 평판
안내서 4개를 작성함
4가이드 댓글
I recently received an approximately 2 year old Logitech g602 mouse. Its scroll is non-functional, either up or down. I do seem to be able to scroll minimally if I press the scroll wheel down. I was wondering if you know how this might be fixed. Anything is appreciated.
Adrian Thomas Rodriguez - 답글 공유
I need a new wheel for this mouse. Where can I buy it? I could not see anyone who sell it
Josefa Parafina - 답글 공유
"Logitech G602 Scroll Wheel Replacement" - completely misleading title. Thanks for wasting people's time.
Myshka - 답글 공유
Merci pour les recommandations. Elles m'ont permis de voir qu'il y avait un fil dessoudé. ça m'aurait bien gêné d'en racheter une autre.
Didielus - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 20
지난 30일: 103
전체 시간: 10,710
