주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech G603 Wheel Encoder Replacement
필요한 것
    1. Logitech G603 Wheel Encoder Replacement, Remove Top Cover & Batteries: 1 단계, 이미지 1개 중 1개
      • Remove magnetic top cover, batteries, and wireless receiver (if currently stored inside the mouse)
      댓글 쓰기
    2. Logitech G603 Wheel Encoder Replacement, Remove Mouse Feet: 2 단계, 이미지 3개 중 1개 Logitech G603 Wheel Encoder Replacement, Remove Mouse Feet: 2 단계, 이미지 3개 중 2개 Logitech G603 Wheel Encoder Replacement, Remove Mouse Feet: 2 단계, 이미지 3개 중 3개
      • Carefully remove the feet to reveal the 4 screws holding the top and bottom shells together
      • NOTE: These feet can be removed carefully enough to be reused. Only the top and bottom feet need to be removed, not the one around the sensor
      댓글 쓰기
    3. Logitech G603 Wheel Encoder Replacement, Remove the four Phillips #00 Screws: 3 단계, 이미지 1개 중 1개
      • Use Phillips #00 to remove the four bottom screws
      댓글 쓰기
    4. Logitech G603 Wheel Encoder Replacement, Separate the Top and Bottom Shells: 4 단계, 이미지 3개 중 1개 Logitech G603 Wheel Encoder Replacement, Separate the Top and Bottom Shells: 4 단계, 이미지 3개 중 2개 Logitech G603 Wheel Encoder Replacement, Separate the Top and Bottom Shells: 4 단계, 이미지 3개 중 3개
      • Start at the top above the left and right click and slowly work your way around the shells until they are separated
      • Be careful not to damage the power connector or ribbon cable going from the top shell's boards/battery to the bottom shell's board
      댓글 쓰기
    5. Logitech G603 Wheel Encoder Replacement, Unplug Power and Ribbon Cables: 5 단계, 이미지 3개 중 1개 Logitech G603 Wheel Encoder Replacement, Unplug Power and Ribbon Cables: 5 단계, 이미지 3개 중 2개 Logitech G603 Wheel Encoder Replacement, Unplug Power and Ribbon Cables: 5 단계, 이미지 3개 중 3개
      • Start with the red and black power cable and gently pull it out
      • Once power cable is removed, you should be able to unfold the two halves and unplug the white ribbon cable
      댓글 쓰기
    6. Logitech G603 Wheel Encoder Replacement, Remove Encoder Ribbon Cable: 6 단계, 이미지 1개 중 1개
      • Gently pull out the black ribbon cable connecting the encoder board to the main board
      댓글 쓰기
    7. Logitech G603 Wheel Encoder Replacement, Remove 5 Phillips #00 Screws: 7 단계, 이미지 1개 중 1개
      • Remove the Phillips #00 screws holding the encoder board in place
      댓글 쓰기
    8. Logitech G603 Wheel Encoder Replacement, Remove Encoder Board & Wheel: 8 단계, 이미지 1개 중 1개
      • Remove the encoder board from the bottom shell
      • Gently remove the wheel from the older encoder board
      • NOTE: The old wheel can be reused in the replacement encoder board
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Jim
회원 가입일: 06/17/23
331 평판
안내서 2개를 작성함
1가이드 댓글
In my case, cleaning the encoder plate in an ultrasonic bath did the trick.
dobromir.dombek - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 44
지난 30일: 216
전체 시간: 6,317
