주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech G733 Battery Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
    1. Logitech G733 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Before you begin, discharge the headset battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Gently pull the right ear pad off, starting from the top.
      • Slide your finger around the edges until it releases completely.
      • Remove the ear pad.
      댓글 쓰기
    2. Logitech G733 Battery Replacement: 2 단계, 이미지 2개 중 1개 Logitech G733 Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the four screws that secure the speaker housing using a Phillips screwdriver.
      • Place these screws on the magnetic pad so you don't lose them.
      댓글 쓰기
    3. Logitech G733 Battery Replacement: 3 단계, 이미지 3개 중 1개 Logitech G733 Battery Replacement: 3 단계, 이미지 3개 중 2개 Logitech G733 Battery Replacement: 3 단계, 이미지 3개 중 3개
      • Lift off the speaker housing with care not to strain the connected cable.
      • Gently wiggle the white battery cable connector side to side while pulling it out to disconnect the battery.
      • Do not pull on the wires.
      댓글 쓰기
    4. Logitech G733 Battery Replacement: 4 단계, 이미지 1개 중 1개
      • Take care not to puncture, twist, or bend the battery as you pry.
      • Remove the battery, using a spudger to gently pry it up if necessary.
      • Reapply adhesive, put the new battery in place, and plug it in.
      댓글 쓰기
결론
To reassemble your device, please follow these instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Antonio Jensen
회원 가입일: 02/14/23
727 평판
안내서 5개를 작성함
5가이드 댓글
This guide is great, but mentioning what kind of battery to purchase for the headset would make it infinitely better...
Darbii Rue - 답글 공유
I fully agree
Gabriel Nunes - 답글 공유
Its a 1.5 phillips on the right side. On the left side its a T5 screw not a T4. And you can easily remove the battery without a spudger. It came out with my bare hands.
Heather Dasher - 답글 공유
took 2 mins to find battery info ..........................
Logi 533-000181
Stephen Burrows - 답글 공유
after a quick search i bought this and it fit:
https://he.aliexpress.com/item/100500538...
Jad Ghanayem - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 19
지난 30일: 66
전체 시간: 17,337
