주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech G733 Power Button Replacement
필요한 것
    1. Logitech G733 Power Button Replacement, Power Button: 1 단계, 이미지 1개 중 1개
      • Before you begin, discharge the headset battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Gently start to pull the left ear pad off, starting from the top.
      • Slide your finger around the edges until it releases completely.
      • Remove the ear pad.
      댓글 쓰기
    2. Logitech G733 Power Button Replacement: 2 단계, 이미지 2개 중 1개 Logitech G733 Power Button Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the four screws securing the speaker housing using a T4 Torx screwdriver.
      • Place these screws on the magnetic project mat so you don't lose them.
      댓글 쓰기
    3. Logitech G733 Power Button Replacement: 3 단계, 이미지 3개 중 1개 Logitech G733 Power Button Replacement: 3 단계, 이미지 3개 중 2개 Logitech G733 Power Button Replacement: 3 단계, 이미지 3개 중 3개
      • Gently lift off the speaker housing, with care not to strain the connected cable.
      • Remove the screw on the bottom right-hand side of the motherboard using a Phillips #000 screwdriver.
      • Use your thumb to gently pull back the tab at the upper right-hand corner of the headphone and simultaneously pull the circuit board out.
      • The scroll wheel may fly out when you pop the circuit board out.
      댓글 쓰기
    4. Logitech G733 Power Button Replacement: 4 단계, 이미지 2개 중 1개 Logitech G733 Power Button Replacement: 4 단계, 이미지 2개 중 2개
      • Once the motherboard is loose, gently pull the wire out of its harness.
      • The wiring harness is glued, so be careful with it. It should pull out easily.
      댓글 쓰기
    5. Logitech G733 Power Button Replacement: 5 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Halberd Spudger
      $2.99
      • Pop the power button out of its recess by pushing it through the side of the headphone with your finger.
      • Now use the hook end of the halberd spudger to pry the connecting piece of the power button off at the end furthest to the inside of the headphone.
      • This step is the most difficult, so be careful when prying.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Antonio Jensen
회원 가입일: 02/14/23
727 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 18
지난 30일: 62
전체 시간: 2,633
