소개
Use this guide to remove and replace the feet (also called skates or pads) on the bottom of a Logitech G903.
With sufficient heat, it’s possible to cleanly remove the feet, but you may need replacements if one rips or any adhesive is left behind.
필요한 것
Slide an opening pick under an edge of the bottom mouse foot.
Slide the pick under the rest of the foot until you can lift it off the mouse.
Remove the foot.
Slide the flat end of a spudger under an edge of the adhesive. If the adhesive seems stuck, you may need to heat the adhesive further.
Peel the adhesive off.
Repeat the previous mouse feet removal procedure to remove:
The top mouse foot
The two pentagonal mouse feet on the left and right side
The two small mouse feet in the center
