주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech Gamepad F310 Trigger Spring Replacement
필요한 것
  1. Logitech Gamepad F310 Trigger Spring Replacement, Case: 1 단계, 이미지 2개 중 1개 Logitech Gamepad F310 Trigger Spring Replacement, Case: 1 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
    댓글 쓰기
  2. Logitech Gamepad F310 Trigger Spring Replacement: 2 단계, 이미지 2개 중 1개 Logitech Gamepad F310 Trigger Spring Replacement: 2 단계, 이미지 2개 중 2개
    • Press along the seams of the controller and gently pull the front and rear case apart.
    • If necessary, use an opening tool to help pry the front and rear case apart.
    • Make sure to open the controller with the front facing down so that the buttons do not fall out.
    댓글 쓰기
  3. Logitech Gamepad F310 Trigger Spring Replacement: 3 단계, 이미지 1개 중 1개
    • Separate the front and rear case.
    • There are two side panels on the controller that come apart as well. When putting them back together, they slot into place on the sides of the controller.
    댓글 쓰기
  4. Logitech Gamepad F310 Trigger Spring Replacement, Trigger Spring: 4 단계, 이미지 2개 중 1개 Logitech Gamepad F310 Trigger Spring Replacement, Trigger Spring: 4 단계, 이미지 2개 중 2개
    • Use a Phillips #1 screwdriver to remove:
    • Four 3 mm screws
    • One 5 mm screw
    • Remove the central silver screw last.
    • Gently lift the motherboard off of the back case and slide the cord out of the top slot.
    댓글 쓰기
  5. Logitech Gamepad F310 Trigger Spring Replacement: 5 단계, 이미지 1개 중 1개
    • Make note of the slot on the controller and the slot on the trigger that the spring is connected to.
    • Press the trigger down until the spring pops loose.
    • You may need to fish the spring out of the pocket it is in. The spring will be accompanied by a small black piece that fits inside the spring.
    댓글 쓰기
  6. Logitech Gamepad F310 Trigger Spring Replacement: 6 단계, 이미지 1개 중 1개
    • In order to properly place the spring into the controller, make sure that the black piece is inside, and make sure each end of the spring goes into the correct slots.
    댓글 쓰기
결론
You're all finished! To reassemble your device, follow these instructions carefully in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Alan Mendoza DracoKing
회원 가입일: 02/05/24
194 평판
안내서 2개를 작성함
1가이드 댓글
I completed this guide in conjunction with this video:
How to disassemble and reassemble the Logitech Gamepad F310
Khalon - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 21
지난 30일: 106
전체 시간: 1,588
