주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech Harmony 650 Battery Terminal Replacement
필요한 것
    1. Logitech Harmony 650 Battery Terminal Replacement, Case: 1 단계, 이미지 2개 중 1개 Logitech Harmony 650 Battery Terminal Replacement, Case: 1 단계, 이미지 2개 중 2개
      • Remove the battery cover by applying pressure to the indented area and pushing the cover toward the rear of the device.
      댓글 쓰기
    2. Logitech Harmony 650 Battery Terminal Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the batteries using the silver pull tab.
      댓글 쓰기
    3. Logitech Harmony 650 Battery Terminal Replacement: 3 단계, 이미지 1개 중 1개
      • Using a J000 Philips head screwdriver remove the four 5mm screws around the rim of the battery chamber.
      댓글 쓰기
    4. Logitech Harmony 650 Battery Terminal Replacement: 4 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      • Remove the small plastic cover beneath the plastic LED housing by using a 3.0 flathead screwdriver and a spudger to pry it off. It is glued to the case. If you are having trouble removing it try applying some heat to loosen the glue.
      댓글 쓰기
    5. Logitech Harmony 650 Battery Terminal Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the two 5mm screws located underneath the cover using a J000 Philips screwdriver bit.
      댓글 쓰기
    6. Logitech Harmony 650 Battery Terminal Replacement: 6 단계, 이미지 2개 중 1개 Logitech Harmony 650 Battery Terminal Replacement: 6 단계, 이미지 2개 중 2개
      • Using a plastic opening tool, pry the case off starting from the top of the device (nearest the transmitter). There are 3 tabs along the side of the case and one at the back.
      • The top led protector plastic cover will also be freed once back is removed.
      댓글 쓰기
    7. Logitech Harmony 650 Battery Terminal Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the rear cover.
      댓글 쓰기
    1. Logitech Harmony 650 Battery Terminal Replacement, Battery Terminal: 8 단계, 이미지 2개 중 1개 Logitech Harmony 650 Battery Terminal Replacement, Battery Terminal: 8 단계, 이미지 2개 중 2개
      • Using the small end of a spudger, pry out the terminal from the interior of the case.
      댓글 쓰기
    2. Logitech Harmony 650 Battery Terminal Replacement: 9 단계, 이미지 1개 중 1개
      • Start from one side and work your way to the other side using the spudger.
      댓글 쓰기
    3. Logitech Harmony 650 Battery Terminal Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the terminal.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Connor Gallagher
회원 가입일: 01/11/16
1,036 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 28
전체 시간: 3,815
