주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech Harmony 950 Keypad Replacement
필요한 것
    1. Logitech Harmony 950 Keypad Replacement, Battery: 1 단계, 이미지 2개 중 1개 Logitech Harmony 950 Keypad Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Make sure the remote control is powered off before starting.
      • Use the Opening Tool to open the port cover at the bottom of the remote control.
      • Bend the cover back to gain easy access to the screws.
      댓글 쓰기
    2. Logitech Harmony 950 Keypad Replacement: 2 단계, 이미지 3개 중 1개 Logitech Harmony 950 Keypad Replacement: 2 단계, 이미지 3개 중 2개 Logitech Harmony 950 Keypad Replacement: 2 단계, 이미지 3개 중 3개
      • Use the Phillips #0 Screwdriver to remove the (2) two 6mm screws.
      • Pull the bottom cover off of the remote control.
      댓글 쓰기
    3. Logitech Harmony 950 Keypad Replacement: 3 단계, 이미지 3개 중 1개 Logitech Harmony 950 Keypad Replacement: 3 단계, 이미지 3개 중 2개 Logitech Harmony 950 Keypad Replacement: 3 단계, 이미지 3개 중 3개
      • Use the Phillips #1 Screwdriver to remove the (2) two 6mm screws.
      • There should be a gap on each side to fit the Opening Tool. Use the Opening Tool to open the back cover (Soft Touch cover) using the gap.
      댓글 쓰기
    4. Logitech Harmony 950 Keypad Replacement: 4 단계, 이미지 3개 중 1개 Logitech Harmony 950 Keypad Replacement: 4 단계, 이미지 3개 중 2개 Logitech Harmony 950 Keypad Replacement: 4 단계, 이미지 3개 중 3개
      • Use the Opening Tool to lift the battery out of the case.
      • Gently pull the cable out of the socket to unplug the battery.
      • Be careful not to damage any part of the remote when pulling the cable out.
      댓글 쓰기
    1. Logitech Harmony 950 Keypad Replacement, Keypad: 5 단계, 이미지 3개 중 1개 Logitech Harmony 950 Keypad Replacement, Keypad: 5 단계, 이미지 3개 중 2개 Logitech Harmony 950 Keypad Replacement, Keypad: 5 단계, 이미지 3개 중 3개
      • Use the J0 Philips Head Screwdriver to remove the three 6mm screws.
      • Push the opening tool into the gap along the side of the remote, then slide it across until you hear clicking sounds.
      • You need to repeat this process for both sides of the remote.
      댓글 쓰기
    2. Logitech Harmony 950 Keypad Replacement: 6 단계, 이미지 3개 중 1개 Logitech Harmony 950 Keypad Replacement: 6 단계, 이미지 3개 중 2개 Logitech Harmony 950 Keypad Replacement: 6 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      $3.99
      • Carefully remove the back cover and place it next to the remote. Be careful not to detach the wire during this process.
      • Use the angled tweezers to carefully pull the white cable end off of the remote and disconnect it.
      댓글 쓰기
    3. Logitech Harmony 950 Keypad Replacement: 7 단계, 이미지 3개 중 1개 Logitech Harmony 950 Keypad Replacement: 7 단계, 이미지 3개 중 2개 Logitech Harmony 950 Keypad Replacement: 7 단계, 이미지 3개 중 3개
      • Use the J0 Philips Head Screwdriver to remove the 5 6mm screws.
      • Be careful not to detach the pink wires when removing the gold charging conductors.
      댓글 쓰기
    4. Logitech Harmony 950 Keypad Replacement: 8 단계, 이미지 3개 중 1개 Logitech Harmony 950 Keypad Replacement: 8 단계, 이미지 3개 중 2개 Logitech Harmony 950 Keypad Replacement: 8 단계, 이미지 3개 중 3개
      • Remove the black tape to access the cable underneath.
      • Use the angled tweezers to flip the black lock up 90° and release the cable.
      • Slide the yellow cable to disconnect it from the circuit board.
      댓글 쓰기
    5. Logitech Harmony 950 Keypad Replacement: 9 단계, 이미지 2개 중 1개 Logitech Harmony 950 Keypad Replacement: 9 단계, 이미지 2개 중 2개
      • Pull the circuit board off of the remote from the bottom, and lift up to detach it from the cover.
      • It can be difficult to detach the circuit board without damaging the connectors. If you just need access to the keypad, lift the board up starting with the bottom, until you can hinge the top end off. Use a tool or pick to hold the board up until you replace it.
      댓글 쓰기
    6. Logitech Harmony 950 Keypad Replacement: 10 단계, 이미지 2개 중 1개 Logitech Harmony 950 Keypad Replacement: 10 단계, 이미지 2개 중 2개
      • Use the Blunt Tweezers to carefully remove the keypad from the cover of the remote.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Blake Sanborn
회원 가입일: 09/26/17
601 평판
안내서 3개를 작성함
USF Tampa, Team S2-G2, Passmore Fall 2017 USF Tampa, Team S2-G2, Passmore Fall 2017 회원
USFT-PASSMORE-F17S2G2
4 회원들
안내서 15개를 작성함
4가이드 댓글
And the replacements parts are purchased from where?
larrybud2004 - 답글 공유
Fruit juice or something sticky was on the keys so had to dismantle, as the keys were hard to press. it seemed just taking it apart fixed it, no cleaning needed. But still took almost an hour to completely dismantle and reassemble.
Some feedback on the guide. Once you access the PCB, and you need to remove the gold charging conductors at the bottom. Mine didn't come out, they both seem hooked in. So in the end I left them in and wiggled the PCB out instead. I think you might need to break the small plastic pits that hold in the charging conductors .
Jonathan Willis - 답글 공유
I agree with Jonathan, it is not possible to remove the gold charging conductors without breaking the small centered plastic pin that is holding them. However taking it appart and having the buttons a bit loose once the screws where removed did the trick!
Armand - 답글 공유
Just a smaller comment - step 7 picture 1 shows the position of the three screws. The one in the middle on the PCB is not pictured correctly.
Ronnie Persson - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 52
전체 시간: 2,593
