주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech K270 Cleanup
    • Unplug the USB receiver from any device if you have one connected to a PC/Mac/Chromebook/Raspberry Pi, or else, you’ll be charged €50/£50/$50 for repairs.
    댓글 쓰기
    • Press the blow button if you have a blow dryer to blow the dirt out
    • If you don’t have a Blow dryer, use a brush to brush everything out
    댓글 쓰기
    • If any further dust (like this 5yr old K270), remove keys carefully to ensure they are removed
    • Do not remove the keys too hard because it is a very cheap keyboard and you could damage the keys, preventing you from putting the keys back to the frame again.
    댓글 쓰기
    • Clean dust in the keyboard so you can clean it properly and carefully to perfection.
    • You could remove the top keys, but it’ll be too complicated
    댓글 쓰기
    • Remove 8 Phillips screws that secure the under side to the base enclosure
    • Pry the keyboard and remove the back cover from the main keyboard frame
    댓글 쓰기
    • Remove the 2 layers of the keyboard
    • Don’t call them silly names! 🐶
    댓글 쓰기
    • Remove the main board (may have 2 Phillips that secure the mainboard)
    댓글 쓰기
    • Dip the bottom cover or the front cover in soapy water for about a few hours.
    • If it is EXTREMELY dirty, you could use UV rays to do that
    댓글 쓰기
    • Well done for cleaning your Logitech K270, it feels like brand new again! Plug the USB receiver back to your PC/Mac/Chromebook/Raspberry Pi and enjoy using your new keyboard!
    댓글 쓰기
결론
To reassemble your device, reverse steps 5 - 7 (optional steps 1 - 3). Remember it could sometimes get too overcomplicated for it to be repaired.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Dell LatitudeStudios
회원 가입일: 05/28/25
630 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 37
전체 시간: 441
