주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech K480 Keycap Replacement
필요한 것
    1. Logitech K480 Keycap Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Flip the keyboard over.
      댓글 쓰기
    2. Logitech K480 Keycap Replacement: 2 단계, 이미지 3개 중 1개 Logitech K480 Keycap Replacement: 2 단계, 이미지 3개 중 2개 Logitech K480 Keycap Replacement: 2 단계, 이미지 3개 중 3개
      • Remove the four rubber feet with a spudger.
      댓글 쓰기
    3. Logitech K480 Keycap Replacement: 3 단계, 이미지 3개 중 1개 Logitech K480 Keycap Replacement: 3 단계, 이미지 3개 중 2개 Logitech K480 Keycap Replacement: 3 단계, 이미지 3개 중 3개
      • Slide open battery panel.
      • Remove the batteries.
      댓글 쓰기
    4. Logitech K480 Keycap Replacement: 4 단계, 이미지 2개 중 1개 Logitech K480 Keycap Replacement: 4 단계, 이미지 2개 중 2개
      • Remove the three 4 mm screws under the rubber feet using a Phillips #0 screwdriver.
      댓글 쓰기
    5. Logitech K480 Keycap Replacement: 5 단계, 이미지 2개 중 1개 Logitech K480 Keycap Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the two 4 mm screws from beneath the battery cover using a Phillips #0 screwdriver.
      댓글 쓰기
    6. Logitech K480 Keycap Replacement: 6 단계, 이미지 3개 중 1개 Logitech K480 Keycap Replacement: 6 단계, 이미지 3개 중 2개 Logitech K480 Keycap Replacement: 6 단계, 이미지 3개 중 3개
      • Starting by the dial, slide the spudger between the front and back panels until it lifts and snaps.
      • Slide a blue pick in to keep the pieces apart while you work on other areas.
      • Continue prying along the edges until you have enough opened that you can pull both pieces apart gently with your hands.
      • The loud snaps are the clips that hold the pieces together. They're not breaking and you do not need to be alarmed.
      댓글 쓰기
    1. Logitech K480 Keycap Replacement, Metal Plate: 7 단계, 이미지 3개 중 1개 Logitech K480 Keycap Replacement, Metal Plate: 7 단계, 이미지 3개 중 2개 Logitech K480 Keycap Replacement, Metal Plate: 7 단계, 이미지 3개 중 3개
      • Remove the eight 3 mm screws using a Phillips #00 screwdriver
      • Remove the five 2 mm silver screws from the metal plate using a Phillips #00 screwdriver.
      • Remove the single 4 mm black screw by the motherboard using a Phillips #00 screwdriver.
      댓글 쓰기
    2. Logitech K480 Keycap Replacement: 8 단계, 이미지 2개 중 1개 Logitech K480 Keycap Replacement: 8 단계, 이미지 2개 중 2개
      • Lift up and remove the metal plate.
      댓글 쓰기
    1. Logitech K480 Keycap Replacement, Keycap: 9 단계, 이미지 1개 중 1개
      • Flip the flex circuit and rubber dome sheet over.
      댓글 쓰기
    2. Logitech K480 Keycap Replacement: 10 단계, 이미지 3개 중 1개 Logitech K480 Keycap Replacement: 10 단계, 이미지 3개 중 2개 Logitech K480 Keycap Replacement: 10 단계, 이미지 3개 중 3개
      • Using the spudger, gently press on the underside of the key and pop it out.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Madison
회원 가입일: 09/04/24
778 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 14
지난 30일: 66
전체 시간: 773
