주요 콘텐츠로 건너뛰기
Logitech K830 Battery Replacement
필요한 것
  1. Logitech K830 Battery Replacement, Turn off the keyboard: 1 단계, 이미지 1개 중 1개
    • Flip the keyboard's power switch into the OFF position.
    • A red indicator is visible beneath the switch when it's in the OFF position.
  2. Logitech K830 Battery Replacement, Paritally remove the foot pads: 2 단계, 이미지 3개 중 1개 Logitech K830 Battery Replacement, Paritally remove the foot pads: 2 단계, 이미지 3개 중 2개 Logitech K830 Battery Replacement, Paritally remove the foot pads: 2 단계, 이미지 3개 중 3개
    • Insert the pointed end of a spudger under the edge of one of the feet.
    • Push the spudger underneath the outside edge of the foot and pry up to release its adhesive.
    • The edge of the foot should come away from the keyboard without much force. Pry slowly to avoid tearing the foot or removing it fully.
    • Once the edge is up, you will be able to see the heads of the screw underneath. There is no need to fully remove the foot, which damages the adhesive.
    • Repeat this step for the remaining three feet.
  3. Logitech K830 Battery Replacement, Remove the eight screws: 3 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the eight 6.8 mm-long screws securing the upper case to the lower case.
  4. Logitech K830 Battery Replacement, Release the clips: 4 단계, 이미지 2개 중 1개 Logitech K830 Battery Replacement, Release the clips: 4 단계, 이미지 2개 중 2개
    • The upper case is secured to the lower case by clips on every side of the keyboard. In the next steps, you'll release the clips on each side.
    • Insert an opening pick about 2 mm into the gap between the upper case and lower case at the bottom-right corner of the keyboard.
    • This creates a gap large enough to insert the flat end of a spudger.
  5. Logitech K830 Battery Replacement: 5 단계, 이미지 3개 중 1개 Logitech K830 Battery Replacement: 5 단계, 이미지 3개 중 2개 Logitech K830 Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Don't insert the spudger more than 2 mm into the keyboard or you may damage internal components.
    • The internal battery is located near the right edge of the keyboard. Take care not to puncture or bend the battery with your spudger—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Insert the flat end of a spudger about 2 mm into the gap between the upper case and lower case in the bottom right corner of the keyboard.
    • Rotate the spudger clockwise to release the first clip.
  6. Logitech K830 Battery Replacement: 6 단계, 이미지 3개 중 1개 Logitech K830 Battery Replacement: 6 단계, 이미지 3개 중 2개 Logitech K830 Battery Replacement: 6 단계, 이미지 3개 중 3개
    • Move the spudger about 3 cm along the keyboard's edge toward the volume buttons.
    • Rotate the spudger clockwise to release the next clip.
  7. Logitech K830 Battery Replacement: 7 단계, 이미지 2개 중 1개 Logitech K830 Battery Replacement: 7 단계, 이미지 2개 중 2개
    • The spudger should now be about in the middle of the right edge of the keyboard.
  8. Logitech K830 Battery Replacement: 8 단계, 이미지 2개 중 1개 Logitech K830 Battery Replacement: 8 단계, 이미지 2개 중 2개
    • Move the spudger another 3 cm toward the volume buttons and repeat the previous step.
  9. Logitech K830 Battery Replacement: 9 단계, 이미지 2개 중 1개 Logitech K830 Battery Replacement: 9 단계, 이미지 2개 중 2개
    • The spudger should now be at the top-right of the keyboard.
  10. Logitech K830 Battery Replacement: 10 단계, 이미지 3개 중 1개 Logitech K830 Battery Replacement: 10 단계, 이미지 3개 중 2개 Logitech K830 Battery Replacement: 10 단계, 이미지 3개 중 3개
    • Repeat the clip release procedure for the left edge of the keyboard.
  11. Logitech K830 Battery Replacement: 11 단계, 이미지 2개 중 1개 Logitech K830 Battery Replacement: 11 단계, 이미지 2개 중 2개
    • Don't insert the opening pick more than 2 mm into the case or you may damage internal components.
    • Insert an opening pick about 2 mm into the gap between the upper case and the gray support bar closest to the volume buttons.
  12. Logitech K830 Battery Replacement: 12 단계, 이미지 3개 중 1개 Logitech K830 Battery Replacement: 12 단계, 이미지 3개 중 2개 Logitech K830 Battery Replacement: 12 단계, 이미지 3개 중 3개
    • Slide the opening pick across the entire length of the keyboard to release the clips on the top edge.
  13. Logitech K830 Battery Replacement: 13 단계, 이미지 3개 중 1개 Logitech K830 Battery Replacement: 13 단계, 이미지 3개 중 2개 Logitech K830 Battery Replacement: 13 단계, 이미지 3개 중 3개
    • Repeat the last step for the bottom of the keyboard.
  14. Logitech K830 Battery Replacement, Open the upper case: 14 단계, 이미지 3개 중 1개 Logitech K830 Battery Replacement, Open the upper case: 14 단계, 이미지 3개 중 2개 Logitech K830 Battery Replacement, Open the upper case: 14 단계, 이미지 3개 중 3개
    • Don't try to remove the upper case completely—it's still attached to the lower case by a delicate interconnect cable.
    • Lift the upper case up by about 2 cm.
    • If the upper case doesn't lift completely off of the lower case, repeat the clip release procedure for the stuck area.
    • Tilt the upper case about 45 degrees so that the keycap letters are upside-down.
    • Keep the upper case as close to the lower case as possible to avoid straining the interconnect cable.
  15. Logitech K830 Battery Replacement: 15 단계, 이미지 2개 중 1개 Logitech K830 Battery Replacement: 15 단계, 이미지 2개 중 2개
    • Place the top edge of the upper case on your work surface as close to the lower case as possible.
    • Hold the upper case at about 45 degrees to avoid straining the interconnect cable.
  16. Logitech K830 Battery Replacement, Gray support bar information: 16 단계, 이미지 2개 중 1개 Logitech K830 Battery Replacement, Gray support bar information: 16 단계, 이미지 2개 중 2개
    • If the gray support bars fall out during this repair, place them back into their slots with their notches facing upward.
  17. Logitech K830 Battery Replacement, Disconnect the interconnect cable: 17 단계, 이미지 2개 중 1개 Logitech K830 Battery Replacement, Disconnect the interconnect cable: 17 단계, 이미지 2개 중 2개
    • Remove the black tape covering the interconnect cable connector.
    • Set this tape aside. During reassembly, place the tape back into its original position on the motherboard. Be careful not to damage any of the surface-mounted components.
  18. Logitech K830 Battery Replacement: 18 단계, 이미지 3개 중 1개 Logitech K830 Battery Replacement: 18 단계, 이미지 3개 중 2개 Logitech K830 Battery Replacement: 18 단계, 이미지 3개 중 3개
    • Use the pointed end of a spudger to push the interconnect cable connector's locking tab toward the cable.
    • The connector is unlocked when the locking tab lines up with the white rectangle on the motherboard.
  19. Logitech K830 Battery Replacement: 19 단계, 이미지 2개 중 1개 Logitech K830 Battery Replacement: 19 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a pair of blunt tweezers to grip the interconnect cable by the blue section close to the connector.
    • Pull the interconnect cable out of its connector in the direction of the cable.
    • During reassembly, follow these steps to reconnect the interconnect cable:
    • Make sure the locking tab is in the unlocked position.
    • Insert the ribbon cable so that the black line on the cable lines up with the white rectangle's edge closest to the cable.
    • Use your fingernail to move the locking tab into the locked position.
  20. Logitech K830 Battery Replacement, Remove the upper case: 20 단계, 이미지 1개 중 1개
    • Remove the upper case from the lower case.
  21. Logitech K830 Battery Replacement, Disconnect the battery: 21 단계, 이미지 2개 중 1개 Logitech K830 Battery Replacement, Disconnect the battery: 21 단계, 이미지 2개 중 2개
    • Remove the yellow tape covering the battery cables.
    • Set this tape aside. During reassembly, place the tape back into its original position covering the cables on the battery.
  22. Logitech K830 Battery Replacement: 22 단계, 이미지 1개 중 1개
    • Take care not to puncture or bend the battery—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Apply a few drops of high-concentration (90% or higher) isopropyl alcohol under the battery edge opposite the battery connector.
    • Wait one minute for the isopropyl alcohol to weaken the adhesive under the battery.
  23. Logitech K830 Battery Replacement: 23 단계, 이미지 3개 중 1개 Logitech K830 Battery Replacement: 23 단계, 이미지 3개 중 2개 Logitech K830 Battery Replacement: 23 단계, 이미지 3개 중 3개
    • Slowly insert the tip of an opening pick under the top edge of the battery.
    • Make sure the opening pick is sliding under the battery and not pushing into the battery's side.
    • If the opening pick isn't sliding under the battery, apply more isopropyl alcohol and try again.
    • Push about half of the opening pick under the battery while slowly lifting up.
  24. Logitech K830 Battery Replacement: 24 단계, 이미지 2개 중 1개 Logitech K830 Battery Replacement: 24 단계, 이미지 2개 중 2개
    • Use your fingers to lift the battery about 1 cm above the battery recess.
    • Take care not to strain the battery cables while handling the battery or you may damage the battery connector socket.
  25. Logitech K830 Battery Replacement: 25 단계, 이미지 3개 중 1개 Logitech K830 Battery Replacement: 25 단계, 이미지 3개 중 2개 Logitech K830 Battery Replacement: 25 단계, 이미지 3개 중 3개
    • Rotate the battery 45 degrees so that the edge closest to the battery connector rests in the battery recess about 1 cm from the connector.
    • Place two fingers under the bottom side of the battery to support it.
  26. Logitech K830 Battery Replacement: 26 단계, 이미지 3개 중 1개 Logitech K830 Battery Replacement: 26 단계, 이미지 3개 중 2개 Logitech K830 Battery Replacement: 26 단계, 이미지 3개 중 3개
    • While supporting the battery, disconnect the battery by pulling on the three cables as close to the connector as possible.
    • If the battery connector doesn't easily come out of the socket, gently rock it back and forth to "walk" it out of the socket.
    • During reassembly, make sure the battery connector is oriented correctly. The black cable should be on the side closest to the ten solder points on the motherboard.
  27. Logitech K830 Battery Replacement, Remove the battery: 27 단계, 이미지 1개 중 1개
    • Remove the battery from the keyboard.
    • If there's any alcohol solution remaining in the keyboard, carefully wipe it off with a coffee filter or allow it to air dry before installing your battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • During reassembly, follow this guide if you are using a pre-cut adhesive card to secure the battery.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Logitech K830 Answers community for help.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kyle Smith
회원 가입일: 02/01/21
49,268 평판
안내서 123개를 작성함
3가이드 댓글
Thanks Kyle - absolutely superb instructions - couldn't be clearer.
Chris Ellis - 답글
I have this keyboard and the T and V keys stopped responding, I used alcohol to key the contacts at first but ultimatly I used a rubber eraser to "polish' the T contact points. The trick brings that particular key back to life
WingPui Yip - 답글
Hey there, I actually did the same thing with alcohol and had them all the keys working again, but when I came back to the keyboard some time later the keys were not working anymore. What do you mean by "I used a rubber eraser to 'polish' the T contact points"?
What are the T contact points you are talking about?
[deleted] -
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 35
지난 30일: 147
전체 시간: 4,971
