주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech M100 USB Cable Replacement
필요한 것
  1. Logitech M100 USB Cable Replacement, USB Cable: 1 단계, 이미지 2개 중 1개 Logitech M100 USB Cable Replacement, USB Cable: 1 단계, 이미지 2개 중 2개
    • Not all variants of this mouse require the mouse feet to be taken off for disassembly, but their removal is detailed anyway.
    • Carefully remove the feet of the mouse with an opening pick.
    • Keep track of the mouse feet, as you'll be reapplying them at the end of the guide.
    댓글 쓰기
  2. Logitech M100 USB Cable Replacement: 2 단계, 이미지 2개 중 1개 Logitech M100 USB Cable Replacement: 2 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to remove the 10mm screws on the bottom of the mouse.
    • Once all screws are removed, use the plastic opening tool to gently pry the mouse apart. This shouldn't take much force.
    댓글 쓰기
  3. Logitech M100 USB Cable Replacement: 3 단계, 이미지 2개 중 1개 Logitech M100 USB Cable Replacement: 3 단계, 이미지 2개 중 2개
    • Once the mouse is opened, locate the USB cable's 5-pin connector, which is plugged directly into the mouse's mainboard.
    • Take note of the position and route that the USB cable takes before removal. The replacement cable must follow the same route when inserted.
    • Using a plastic opening tool, gently remove the 5-pin connector from the mainboard.
    댓글 쓰기
  4. Logitech M100 USB Cable Replacement: 4 단계, 이미지 2개 중 1개 Logitech M100 USB Cable Replacement: 4 단계, 이미지 2개 중 2개
    • Take the replacement USB cable and connect it to the mainboard.
    댓글 쓰기
  5. Logitech M100 USB Cable Replacement: 5 단계, 이미지 2개 중 1개 Logitech M100 USB Cable Replacement: 5 단계, 이미지 2개 중 2개
    • Ensure that the 5-pin connector is fully seated into its slot on the mainboard. You may want to use a spudger to apply pressure onto it.
    • Using a plastic opening tool, route the cable through the case in the same way that was noted in Step 3.
    댓글 쓰기
  6. Logitech M100 USB Cable Replacement: 6 단계, 이미지 1개 중 1개
    • After re-assembling the mouse, don't forget to reattach the mouse feet onto their correct locations on the bottom of the mouse.
    댓글 쓰기
결론
To reassemble, follow the steps in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jake Janicke
회원 가입일: 10/26/17
161 평판
안내서 1개를 작성함
1가이드 댓글
Removing the mouse feet is completely unnecessary, as there are no screws underneath the feet.
Andy Joonseo Bae - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 35
전체 시간: 6,539
