주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech M215 Battery Replacement
필요한 것
    1. Logitech M215 Battery Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 1개 Logitech M215 Battery Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 2개 Logitech M215 Battery Replacement, Remove the battery cover: 1 단계, 이미지 3개 중 3개
      • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
      • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
      • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
      댓글 쓰기
    2. Logitech M215 Battery Replacement, Remove old battery: 2 단계, 이미지 1개 중 1개
      • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 28명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Hannah Pate
회원 가입일: 01/30/15
1,742 평판
안내서 7개를 작성함
USF Tampa, Team 1-1, Watkins Winter 2015 USF Tampa, Team 1-1, Watkins Winter 2015 회원
USFT-WATKINS-W15S1G1
4 회원들
안내서 48개를 작성함
10가이드 댓글
I disassembled this exactly as stated and now I can't get the cover back on?
Rei Peterson - 답글 공유
I am a electronic technologist and this is a poor design for a mouse. No wonder the later version is different.
Joseph Wonderless - 답글 공유
Thanks for the information. It worked perfectly for me. Easy removal. Images and instructions were very helpful.
Tracy Moore - 답글 공유
The green battery light went on, although the lazar light did not. What should I do?
Susan Petho - 답글 공유
well this is a bit horrible, because i don’t have an extra AA battery.. and i have a M325, but the battery life is dead..
Diana Lee - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 53
지난 30일: 243
전체 시간: 124,406
