주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech M310 Mouse Wheel Spring Repair
필요한 것
  1. Logitech M310 Mouse Wheel Spring Repair, Logitech M310 Mouse Wheel Spring Repair: 1 단계, 이미지 2개 중 1개 Logitech M310 Mouse Wheel Spring Repair, Logitech M310 Mouse Wheel Spring Repair: 1 단계, 이미지 2개 중 2개
    • Check if the scroll wheel is spinning freely without resistance.
    • A correctly aligned spring will cause the wheel to ratchet in small increments
    댓글 쓰기
  2. Logitech M310 Mouse Wheel Spring Repair: 2 단계, 이미지 3개 중 1개 Logitech M310 Mouse Wheel Spring Repair: 2 단계, 이미지 3개 중 2개 Logitech M310 Mouse Wheel Spring Repair: 2 단계, 이미지 3개 중 3개
    • Use your thumb to press the indentation on the bottom battery cover.
    • Slide down the battery cover and fully remove the battery cover.
    • Remove the battery.
    댓글 쓰기
  3. Logitech M310 Mouse Wheel Spring Repair: 3 단계, 이미지 3개 중 1개 Logitech M310 Mouse Wheel Spring Repair: 3 단계, 이미지 3개 중 2개 Logitech M310 Mouse Wheel Spring Repair: 3 단계, 이미지 3개 중 3개
    • Remove two Phillips #1 screws.
    댓글 쓰기
  4. Logitech M310 Mouse Wheel Spring Repair: 4 단계, 이미지 3개 중 1개 Logitech M310 Mouse Wheel Spring Repair: 4 단계, 이미지 3개 중 2개 Logitech M310 Mouse Wheel Spring Repair: 4 단계, 이미지 3개 중 3개
    • Remove the bottom board plate from the mouse body by pulling it down and away.
    • Ensure not to apply the force perpendicular to the mouse body. The board will only remove in a downward direction.
    댓글 쓰기
  5. Logitech M310 Mouse Wheel Spring Repair: 5 단계, 이미지 3개 중 1개 Logitech M310 Mouse Wheel Spring Repair: 5 단계, 이미지 3개 중 2개 Logitech M310 Mouse Wheel Spring Repair: 5 단계, 이미지 3개 중 3개
    • Use the 2mm flat head to lift up the spring leg.
    • Use the screwdriver as a lever to pry the spring leg back into the scroll wheel
    • You may need to use your thumb to pull the scroll wheel to the left a few millimeters, creating enough of a gap on the right side for the spring leg to fit into the mouse wheel cavity.
    • The spring leg should no longer be visible once aligned inside the mouse wheel cavity.
    댓글 쓰기
  6. Logitech M310 Mouse Wheel Spring Repair: 6 단계, 이미지 3개 중 1개 Logitech M310 Mouse Wheel Spring Repair: 6 단계, 이미지 3개 중 2개 Logitech M310 Mouse Wheel Spring Repair: 6 단계, 이미지 3개 중 3개
    • Before reassembling the mouse, confirm if the scroll wheel is fixed appropriately.
    • Gently place the mouse down on the table and scroll the wheel. There should now be a noticeable difference in resistance, and it should no longer freely spin.
    • If the scroll wheel is still not fixed, you may need to readjust the spring into the cavity again (see Step 5).
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 12명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Karmit Dandona
회원 가입일: 02/18/20
437 평판
안내서 1개를 작성함
UC Davis, Team S2-G2, Andersen Winter 2020 UC Davis, Team S2-G2, Andersen Winter 2020 회원
UCD-ANDERSEN-W20S2G2
4 회원들
안내서 3개를 작성함
9가이드 댓글
Great tutorial. I thought I needed to buy another one. With this I managed to fix it under 2 minutes. Thanks! :)
StopShop GSM - 답글 공유
Excellent instructions, I searched the web for days looking for the solution. I could not determine if it was software or hardware, the mouse wheel has always spun free, no clicking. After following your instructions, it clicks when I scroll and the spontaneous jumping is gone. Thanks a million!
Bob Weenig - 답글 공유
Fantastic instructions! I was struggling to find out how the spring should be placed for the proper ratcheting behavior. This walk-through got me there in less than a minute. Thank you very much!
Sean Smith - 답글 공유
Is there any way to replace the spring if lost?
Connor - 답글 공유
Thanks so much for the great tutorial. The pictures really helped.
Maureen - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 65
지난 30일: 199
전체 시간: 12,275
