주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech M331 Disassembly
필요한 것
    1. Logitech M331 Disassembly, Remove the bottom screw: 1 단계, 이미지 1개 중 1개
      • Flip the mouse over so the power switch is facing up.
      • Slide the battery door towards the back of the mouse to release its clips and remove it.
      • Remove the battery (if installed).
      • Remove the sticker from the battery well.
      • Use a Phillips screwdriver to remove the black screw in the battery well.
      댓글 쓰기
    2. Logitech M331 Disassembly: 2 단계, 이미지 1개 중 1개
      • Carefully detach the upper case and the lower case of the mouse by holding the lower case and sliding the upper case forward.
      댓글 쓰기
    3. Logitech M331 Disassembly: 3 단계, 이미지 1개 중 1개
      • Unscrew the screw in the purple circle and unfasten the plastic pins in blue circles to remove the board from the plastic cover.
      댓글 쓰기
    4. Logitech M331 Disassembly: 4 단계, 이미지 2개 중 1개 Logitech M331 Disassembly: 4 단계, 이미지 2개 중 2개
      • To disassemble the upper case of the mouse, detach the plastic pins located in the blue circles. The two pins located in purple circles will be automatically unfastened once the four blue pins are detached.
      • To disassemble the light propagator, detach the small plastic pin at the bottom of the mouse case and light propagator connection.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 24명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
garfieldknight
회원 가입일: 02/13/19
1,157 평판
안내서 2개를 작성함
9가이드 댓글
first time using ifixit
this was just what i needed thanks!
Prentiss Johnson - 답글 공유
Thanks for the guide! I was able to clean the scroll wheel properly and fixed the annoying inaccurate scroll issue.
Gabriel Louie Cubelo - 답글 공유
Exactly what I needed, a clear and direct guide. Thank you so much!
Zıbın Zıbınoğlu - 답글 공유
Finally my mouse-wheel has stopped ghost scrolling, I used to have this problem where when I scrolled down and up it would go the opposite direction, at first I thought it was a bug but turns out on my other wired logitech mouse, it worked normally.
Upon following this instruction manual (A++) I managed to put some WD40 in the mouse wheel scrolling part, from the inside (not the wheel but the thing it’s attached to) and scrolled it a couple of times, now it works normally :)
Thanks to the author!
TAY CHU TSE ANDREW - 답글 공유
Thanks, cleaning up my M331 and put nachi tape on right-mouse-button so it works again (after it deform slightly).
yayanm 1k - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 50
지난 30일: 206
전체 시간: 18,656
