주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech MBJ58 Mouse Resistance Spring Replacement
필요한 것
    1. Logitech MBJ58 Mouse Resistance Spring Replacement, Top cover: 1 단계, 이미지 1개 중 1개
      • Hold the mouse so that the bottom is facing up.
      • Remove the single Phillips #1 screw from the bottom half of the mouse.
      댓글 쓰기
    2. Logitech MBJ58 Mouse Resistance Spring Replacement: 2 단계, 이미지 2개 중 1개 Logitech MBJ58 Mouse Resistance Spring Replacement: 2 단계, 이미지 2개 중 2개
      • Place the mouse so that the bottom is resting against a hard surface.
      • Lift the top cover of the mouse gently, and remove it.
      댓글 쓰기
    1. Logitech MBJ58 Mouse Resistance Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: 3 단계, 이미지 3개 중 1개 Logitech MBJ58 Mouse Resistance Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: 3 단계, 이미지 3개 중 2개 Logitech MBJ58 Mouse Resistance Spring Replacement, Removing the Logitech MBJ58 Mouse Scroll Wheel: 3 단계, 이미지 3개 중 3개
      • Locate the scroll wheel on the mouse.
      • Grab the scroll wheel with your thumb and index finger.
      • Gently lift up, to remove the scroll wheel from the mouse.
      댓글 쓰기
    1. Logitech MBJ58 Mouse Resistance Spring Replacement, Support Spring: 4 단계, 이미지 2개 중 1개 Logitech MBJ58 Mouse Resistance Spring Replacement, Support Spring: 4 단계, 이미지 2개 중 2개
      • Locate the spring on the scroll wheel, and carefully remove the spring.
      댓글 쓰기
    2. Logitech MBJ58 Mouse Resistance Spring Replacement, Attaching the New Spring: 5 단계, 이미지 2개 중 1개 Logitech MBJ58 Mouse Resistance Spring Replacement, Attaching the New Spring: 5 단계, 이미지 2개 중 2개
      • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
      댓글 쓰기
    1. Logitech MBJ58 Mouse Resistance Spring Replacement, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: 6 단계, 이미지 3개 중 1개 Logitech MBJ58 Mouse Resistance Spring Replacement, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: 6 단계, 이미지 3개 중 2개 Logitech MBJ58 Mouse Resistance Spring Replacement, Disassembling Logitech MBJ58 Mouse Scroll wheel from mount: 6 단계, 이미지 3개 중 3개
      • Use the images to locate where the resistance spring is.
      • This spring will easily fall off.
      • Grab the scroll wheel and its mount and gently pull them apart.
      댓글 쓰기
    1. Logitech MBJ58 Mouse Resistance Spring Replacement, Resistance Spring: 7 단계, 이미지 2개 중 1개 Logitech MBJ58 Mouse Resistance Spring Replacement, Resistance Spring: 7 단계, 이미지 2개 중 2개
      • Grasp the top of the resistance spring and pull it towards yourself, letting the hook slide out of its hole.
      댓글 쓰기
    2. Logitech MBJ58 Mouse Resistance Spring Replacement: 8 단계, 이미지 1개 중 1개
      • Insert the hooked section of the replacement spring into the corresponding hole on the mount.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 15명이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
Maximilian Betkowski
회원 가입일: 01/11/13
238 평판
안내서 4개를 작성함
Cal Poly, Team 5-14, Forte Winter 2013 Cal Poly, Team 5-14, Forte Winter 2013 회원
CPSU-FORTE-W13S5G14
5 회원들
안내서 56개를 작성함
10가이드 댓글
This mouse was also available from Dell as an OEM device under the model name "M-UVDEL1". Hopefully the Google juice will help folks repair their devices. I know I would have spent far more time than I did if it weren't for the photos on how to put the spring back. Thanks Maximilian!
Bastien Nocera - 답글 공유
The spring installation details were lifesavers. Thank you!
LB
byard - 답글 공유
thank you! could not have done it without your help.
taiyo_yuden_dvd - 답글 공유
Brilliant. Thanks. Easy once you know how. The springs were the hard part.
Charles Thomson - 답글 공유
Thank you so much!! You made it very easy and quick!
vulcanmeister - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 19
지난 30일: 97
전체 시간: 13,621
