주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech MX Master 3S Clicker Replacement
필요한 것
    1. Logitech MX Master 3S Clicker Replacement, Clicker: 1 단계, 이미지 2개 중 1개 Logitech MX Master 3S Clicker Replacement, Clicker: 1 단계, 이미지 2개 중 2개
      • Flip the mouse over and power the device off.
      댓글 쓰기
    2. Logitech MX Master 3S Clicker Replacement: 2 단계, 이미지 3개 중 1개 Logitech MX Master 3S Clicker Replacement: 2 단계, 이미지 3개 중 2개 Logitech MX Master 3S Clicker Replacement: 2 단계, 이미지 3개 중 3개
      • Using a T4 Torx screwdriver, remove the top screw in the center area below the clicker surfaces.
      • Using an opening tool, lift and remove the skate pads.
      댓글 쓰기
    3. Logitech MX Master 3S Clicker Replacement: 3 단계, 이미지 2개 중 1개 Logitech MX Master 3S Clicker Replacement: 3 단계, 이미지 2개 중 2개
      • Using a Phillips screwdriver, remove the screws holding the footing in place.
      댓글 쓰기
    4. Logitech MX Master 3S Clicker Replacement: 4 단계, 이미지 3개 중 1개 Logitech MX Master 3S Clicker Replacement: 4 단계, 이미지 3개 중 2개 Logitech MX Master 3S Clicker Replacement: 4 단계, 이미지 3개 중 3개
      • Insert a plastic opening tool into the seam between the top shell and the bottom case along the side of the mouse.
      • Once all clips are released, carefully lift the top shell, but do not remove it completely yet—internal cables are still attached.
      • Support the top shell with one hand so the cable is not strained.
      • Gently disconnect the ribbon cable (or small connector) linking the top shell to the main board.
      댓글 쓰기
    5. Logitech MX Master 3S Clicker Replacement: 5 단계, 이미지 3개 중 1개 Logitech MX Master 3S Clicker Replacement: 5 단계, 이미지 3개 중 2개 Logitech MX Master 3S Clicker Replacement: 5 단계, 이미지 3개 중 3개
      • Remember this cable orientation for reassembly.
      • Using a Phillips screwdriver, remove the battery by unscrewing the screws at each corner.
      댓글 쓰기
    6. Logitech MX Master 3S Clicker Replacement: 6 단계, 이미지 3개 중 1개 Logitech MX Master 3S Clicker Replacement: 6 단계, 이미지 3개 중 2개 Logitech MX Master 3S Clicker Replacement: 6 단계, 이미지 3개 중 3개
      • Remove the mouse wheel by unscrewing the screws from the bracket to the motherboard.
      • Remove the screws mounting the motherboard to the mouse bottom shell, and remove the motherboard.
      • Release the old clicker/switch by desoldering.
      댓글 쓰기
    7. Logitech MX Master 3S Clicker Replacement: 7 단계, 이미지 3개 중 1개 Logitech MX Master 3S Clicker Replacement: 7 단계, 이미지 3개 중 2개 Logitech MX Master 3S Clicker Replacement: 7 단계, 이미지 3개 중 3개
      • With the old clicker/switch removed, remember to clean your service area on the motherboard before inserting the replacement clicker/switch.
      • Use the soldering iron to solder the clickers securely.
      • Be careful using the soldering iron as it gets very hot. Avoid placing it directly on or near things that could be burned.
      댓글 쓰기
    8. Logitech MX Master 3S Clicker Replacement: 8 단계, 이미지 3개 중 1개 Logitech MX Master 3S Clicker Replacement: 8 단계, 이미지 3개 중 2개 Logitech MX Master 3S Clicker Replacement: 8 단계, 이미지 3개 중 3개
      • Reinsert the motherboard into the mouse housing and secure it in place by rescrewing the screws.
      • Reseat the mouse wheel removed earlier back onto the motherboard bracket.
      • Reinsert the battery and fasten down the corner screws removed previously.
      댓글 쓰기
    9. Logitech MX Master 3S Clicker Replacement: 9 단계, 이미지 3개 중 1개 Logitech MX Master 3S Clicker Replacement: 9 단계, 이미지 3개 중 2개 Logitech MX Master 3S Clicker Replacement: 9 단계, 이미지 3개 중 3개
      • Reconnect the mouse top shell ribbon. Handle gently to avoid damaging the ribbon connector.
      • Reassemble the mouse shell back in place. All seams should be aligned when properly in place.
      댓글 쓰기
    10. Logitech MX Master 3S Clicker Replacement: 10 단계, 이미지 3개 중 1개 Logitech MX Master 3S Clicker Replacement: 10 단계, 이미지 3개 중 2개 Logitech MX Master 3S Clicker Replacement: 10 단계, 이미지 3개 중 3개
      • Screw in each bottom plate screw to secure the device in place.
      • Apply mouse skate pads carefully aligned with the cutout. Remove plastic protector covers.
      • New mouse skates are recommended. This is optional, however.
      댓글 쓰기
    11. Logitech MX Master 3S Clicker Replacement: 11 단계, 이미지 1개 중 1개
      • Power on the mouse and open the Logi Options+ software to confirm it's properly connecting and functioning.
      댓글 쓰기
결론
Your Logitech MX Master 3S is now back in action with a new clicker/switch. The desoldering and resoldering process may take some practice, but the result is a fully restored, responsive mouse.
Before reassembling, test the new switch to ensure proper click registration and smooth operation. If everything feels right, reattach the mouse feet pads and screw everything back together.
Enjoy your refreshed mouse!
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Eric S.
회원 가입일: 03/11/26
249 평판
안내서 1개를 작성함
4가이드 댓글
Thank you for the guide. How is the click profile of the switches compared to the original?
Carlos - 답글 공유
@carlosunch It seems to be close to the original. The replacement switches were meant to be more silent as not to make much noise but it feels very close to the original in my opinion.
Eric S. - 답글 공유
Are you sure your mouse is the 'S' version and not the regular 3, as i see some small differences between my 3S and some of your photo's. (.e.g. the extra screw on the bottom, see my previous comment). Furthermore, excellent guide!!!
Chris N. - 답글 공유
@chrisn95097 Hi Chris and thanks for the feedback. It's the 3S as can be seen on the step 2 images. The images may not have shown all screws but it's advised to have a narrow enough screwdriver to insert all the way in to unscrew it.
Eric S. - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 84
지난 7일: 560
지난 30일: 2,488
전체 시간: 4,755
